D9G Manual Powershift
Showing 1 to 10 of 22 results
d4c24a
D9g that has appeared on Facebook , Manual with powershift , was a special order , anybody ever came across similar
Fri, May 24, 2019 9:18 PM
Thank you received: 77
I thought all powershifts were manual, in the sense that if you put it in 3F for example, then that's the gear selected and it won't change to any other gear automatically (like an automatic would). Do they mean something different?
Fri, May 24, 2019 10:18 PM
Thank you received: 140
Hi, Neil.
If you have a look at the floor just left and forrard of the operator's seat, you may notice a long lever poking up from the floor with a forward lean to it. See if it reminds you of some similar sight from a long distant past.
Sat, May 25, 2019 12:57 AM
Hi, Neil.
Are you sure they have the model correct? What's the s/n?
Seems more like a D9E 50Axxxx Direct Drive and Torque Converter or a 49Axxxx Direct Drive.
They didn't make many of either.
Sat, May 25, 2019 1:55 AM
Hi, Old Magnet.
I would suggest that it is a D9G. The blade control lever and visible front edge of the hydraulic tank are both later D9G after they dropped the front mounted hydraulics and went to the side tank hydraulics.
Sat, May 25, 2019 2:58 PM
Hi, Old Magnet.
I think that lever is for a rear attachment, like a pto.
Sun, May 26, 2019 3:00 AM
Chuck C
I am no expert but the lever on the floor to the left of the seat looks like a clutch lever. It also looks like it has the U shaped gate for a power shift to the left of the seat. I am probably wrong but that what it looks like to me.
Chuck C
Sun, May 26, 2019 8:58 AM
d4c24a
Reply to Chuck C:
Chuck C
Second from last built ?
Sun, May 26, 2019 6:23 PM
d4c24a
Reply to d4c24a:
In its full
Sun, May 26, 2019 6:24 PM
d4c24a
No pto on it :noidea:
Sun, May 26, 2019 6:25 PM
Reply to d4c24a:
Ten-4 i see that now. Looks like it had a cable control on it at one time.
Sun, May 26, 2019 6:47 PM
