D9G E-bay
D9G E-bay
Showing 1 to 10 of 12 results
83Jim
Send a private message to 83Jim
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Fri, Jan 9, 2015 11:23 PM
Fresh paint is nice but always a little suspect.
Don't like the oil leaks weeping from final drive housing and out board bearings.
Pictures cut off where you need to look , like how far forward are the front idlers, how many cracks in the ripper sockets, track frames, etc.
On the plus side it does not appear to be beat to death considering the age of the machine, rails "look" good but need measuring.
Fri, Jan 9, 2015 11:44 PM
hicrop10
Spent 40 plus years either running those old girls or working around them.Was my favorite tractor to run.I think Old Magnet said it right fresh paint kinda scars me.I sold all of ours in there working clothes.That way the buyer can see what is leaking and whats not.I would be more afraid of the main frame of the tractor being crack then anything else.We were doing what Cat calls certified rebuilds long before they started doing them.Wewould bring one of our 9's into the shop and tear it down right to the bear frame and start from there.Hell if it runs it worth the price in parts.The U/C has to be around 40-50 thousand.The finals must be at close to $4000 per side now.
Sat, Jan 10, 2015 5:02 AM
Dan Pratt
Reply to hicrop10:
Delete duplicate post
Sat, Jan 10, 2015 8:01 AM
Dan Pratt
Reply to hicrop10:
Ha! I got a good chuckle when I looked at the listing and it says for Shipping: "Free local pickup".
Nothing is free when it comes to picking up and hauling that beast.
Happy Friday!
Sat, Jan 10, 2015 8:02 AM
Oil Slick
Reply to Dan Pratt:
Happy Friday!
How much one of those weight with the rippers? 35 tons?
Sat, Jan 10, 2015 10:21 AM
d4e
Send a private message to d4e
Reply to Oil Slick:
Mike probably 95,000 -100,000 depending on how much extra iron been welded on and if one has the ROPS enclosed cab
Sat, Jan 10, 2015 10:49 AM
Thank you received: 140
Reply to d4e:
Hi, Folks.
I had to chuckle at the "May not ship to Australia." Why NOT? Do I detect some discrimination happening here? Is he afraid that it'll fall off? Why? Nothing else has - - - - - - - YET.
A kew-ree-yuss mind would like to know.
Sat, Jan 10, 2015 2:13 PM
Oil Slick
Reply to d4e:
Thanks John, guess it's out of mt weight legue, I'm only permitted for a 104,000 with the old KW.
Sat, Jan 10, 2015 9:19 PM
7upuller
Reply to Oil Slick:
Hey OilSlick,
What do you Tare out at with your truck and trailer? :ballchain:
Sat, Jan 10, 2015 9:29 PM
Oil Slick
Reply to 7upuller:
Hey OilSlick,
Pops, 34,500
Mon, Jan 12, 2015 1:45 AM
