D9G Cranking but no start Video Posted On Youtube (Hawaii)
Showing 1 to 9 of 9 results
gvanhouten
Send a private message to gvanhouten
Well the other post seems to have gotten pretty long... This is a continuation of that... Would like to know what people think about the speed the engine is rolling at... Could not post it here as it was to big of a file...
https://youtu.be/BsA_2XpwMK8
Tue, Oct 15, 2019 11:22 PM
BigAgCat
Send a private message to BigAgCat
It sounds like it is cranking fast enough to me.
I don't know what the temperature is like there, but I sort of wonder if you don't have enough heat in the engine to get it running.
Also, maybe consider trying different throttle positions while cranking. Maybe you have too much fuel or too little...
I am kind of a noob though. I put an electric start on my D6 5R. It has no glow plugs and when I tried cranking in the 60-70 degree weather I had yesterday it didn't seem like enough heat to start. I think if I cranked it for maybe a few minutes it maybe eventually would have gotten enough heat to start, but instead of seeing how long it would crank before the batteries were drained, I fired up the pony to heat up the intake and radiator fluid. After running the pony a few minutes, I crank the engine and it starts.
You have to consider that hot air is what makes combustion happen in a diesel. So, the hotter the better. Maybe see if you can heat up the engine more instead of just using the glow plugs if you have them.
Cat D6 5R
Wed, Oct 16, 2019 2:46 AM
gvanhouten
Reply to BigAgCat:
[quote="BigAgCat"]It sounds like it is cranking fast enough to me.
You have to consider that hot air is what makes combustion happen in a diesel. So, the hotter the better. Maybe see if you can heat up the engine more instead of just using the glow plugs if you have them.[/quote]
In Hawaii it can cold and wet of course not what I am use to ie the east coast (New Jersey). But something sitting around and not getting warm metal stays cold... Thank you for your advice it is good advice.. It seems like warming her up would be the best course as she just goes and goes and goes but no boom... It was super close and I bet it was because she was as hot as she has been... I will take your advice and try the weed burner trick...
Wed, Oct 16, 2019 9:36 PM
janmeermans
Reply to gvanhouten:
Are you getting a lot of white smoke while it is cranking? If not, you are not getting fuel to the injectors. Your video does not show the stack exhaust which tells if fuel is present. Give it a little ether. If it fires on ether that helps warm things up in there.
JanM
Wed, Oct 16, 2019 10:31 PM
gvanhouten
Reply to janmeermans:
JanM
[quote="janmeermans"]Are you getting a lot of white smoke while it is cranking? If not, you are not getting fuel to the injectors. Your video does not show the stack exhaust which tells if fuel is present. Give it a little ether. If it fires on ether that helps warm things up in there.
JanM[/quote]
I will show a new video getting some white smoke but not a ton... I have used ether but it rattles the hell out of it...I will post a better video later for review...
Thu, Oct 17, 2019 3:08 AM
JanM[/quote]
If you buy my plane ticket I will have it running in ten minutes, with a return flight of coarse, but make the stay for at least two to three weeks though, gotta watch the surf babes for a while, lol
Thu, Oct 17, 2019 3:20 AM
Thank you received: 78
Here's a video of another electric start unit showing the amount of smoke it'll pump out when starting:
https://www.youtube.com/watch?v=To3753y-8wQ
Thu, Oct 17, 2019 4:14 AM
janmeermans
[quote="Neil"]Here's a video of another electric start unit showing the amount of smoke it'll pump out when starting:
https://www.youtube.com/watch?v=To3753y-8wQ[/quote]
Perfect sample video Neil! That is the smoke I am talking about. I believe he is not getting fuel to the cylinders.
JanM
Fri, Oct 18, 2019 10:37 PM
Thank you received: 140
JanM
Hi, gvanhouten.
First up, WHAT is the reason for the black plastic cover that flutters when you are cranking the engine? If it is over the exhaust, get rid of it while trying to start.
Next, MANY years ago, an old man in DowNunda - Australia - told me that he had had a lot of success holding a gasoline-soaked rag over the air intake while cranking. He would take the air cleaner element right out and tie the rag over the open end so that it could not be sucked in while he cranked the engine over. I have tried it a couple of times and it seemed to work - haven't needed it for quite a while now.
Mon, Oct 21, 2019 7:04 AM
I've had some luck with that too. Seems to work when you're getting fuel injected but just not quite getting over the hump to get it to light off. It's easy to do, don't even have to pull the filters since the gasoline is volatile and goes right through. Where I wanted it to work was when the engine had lost prime and was injecting no fuel, but it seemed to be hit and miss.
Mon, Oct 21, 2019 7:37 AM
