D8K wiring diagram
D8K wiring diagram
Showing 1 to 10 of 12 results
cletracker
Send a private message to cletracker
Does anyone have a wiring diagram for a D8K? Helping a friend with the final touch on his D8K.
[attachment=56108]20191123_151449.jpg[/attachment][attachment=56109]20191123_151436.jpg[/attachment][attachment=56110]20191123_151328.jpg[/attachment][attachment=56111]20191123_151426.jpg[/attachment]
Sun, Nov 24, 2019 1:39 AM
bruce oz
Thank you received: 23
hello ,the wiring diagram is not one loom ,i could remember how much it was to down load this book ,Army D8K Models
https://www.scribd.com/doc/80984525/Caterpillar-D8K-Tractor-Serial-77V5006-UP-Parts-Catalog-TM-5-2410-234-34P
Sun, Nov 24, 2019 2:38 AM
cletracker
Reply to bruce oz:
bruce oz, thanks, I have found several sites with D8K litterature but I hate haveing to leave my credit card number to get a "Free download".
Sun, Nov 24, 2019 3:33 AM
Reply to cletracker:
D8K wiring diagram....
Sun, Nov 24, 2019 3:38 AM
cletracker
Old Magnet, Thanks!!!
So the solenoid is for the A/C... This D8K was manufactured in England, sold new to Namibia and then it ended up in the north of Norway and finaly sold to Sweden.
/Erik
Sun, Nov 24, 2019 5:56 AM
bluox
/Erik
If you want the right wiring schematic for your tractor you need Cat form SENR 2130 ,its available from Cat ,although it should be in your service manual under systems.
Bob
Sun, Nov 24, 2019 8:48 AM
Wombat
Donor
Reply to bluox:
Bob
Whilst your friend is doing a very nice job of restoring the D8K, I note he has painted the interior of the cab yellow, all D8K tractors with cabins I saw had the cabins painted a brownish colour, not sure what it was called, also the dash lights were a red colour so as not to reflect on the glass and make night operation difficult.
Wombat
Sun, Nov 24, 2019 1:28 PM
cletracker
Reply to Wombat:
Wombat
Bob, thanks.
Wombat, Yes I think the cab was brown inside when he started restoring it.
Dows anyone know how many ohms the glow plugs should have?
Sun, Nov 24, 2019 3:40 PM
tctractors
Bob, thanks.
Early Glasgow built K' the wiring diagram is often found within the Parts Book, the glow plugs draw 5 amps per plug so you should see 30 amp draw on the amp gauge showing they are all working correctly, only test the glow plugs on a low output setting battery charger, the heater rail is the same as D9. tctractors
Mon, Nov 25, 2019 12:40 AM
Reply to tctractors:
Glow plugs should test low resistance, 1 ohm or less.
Mon, Nov 25, 2019 1:10 AM
Thank you received: 93
I believe the inner cab paint color could be Mojave Brown.
Dealer should have it--I recall it in spray cans and larger cans.
Mon, Nov 25, 2019 6:12 AM
