D8K 77V9823 transmission harsh shifting
Showing 1 to 10 of 10 results
Nick22australia
Send a private message to Nick22australia
Hi everyone, I just had a look today at a D8K that my uncle is running for a family friend and he is complaining about the harshness when shifting direction.
I gave it a run and it’s been a while but does seem harsh to me , even at very low revs it seem clunky
Want to find out if there is some sort of modulation valve in there to control this?
It’s been about 6 years since I’ve built one of these trannies and just can’t think of it myself, could it have anything to do with that flow control valve for the pump supply??
Thanks in advance
Mon, Mar 4, 2019 7:32 PM
Nick22australia
Also another problem, transmission oil is transferring to the engine.
The transmission pump has been done up which has slowed it down a lot but is there anywhere else it could be getting into the engine?
Is the most likely scenario it’s still leaking from the pump?
Mon, Mar 4, 2019 7:43 PM
Reply to Nick22australia:
The problem with trans oil getting into the engine oil is the seal on the transmission/steering clutch pump may be installed wrong or got damaged.
Mon, Mar 4, 2019 11:55 PM
On the rough shifting, yes there is a modulating relief valve that controls that.
Could be valve setting is not correct.
Adjustment of control linkage not correct.
Load piston or differential and safety valve not moving
Valve springs that are weak or damaged.
Transmission oil in the engine would pretty much have to come in past the rear crankshaft seal.
Oil leakage from the transmission pump seal would dump into the flywheel/torque divider housing.
Too much oil in the flywheel/torque divider housing could be due to:
Bad scavenge pump
Plugged inlet screen for the scavenge pump
Excessive leakage inside the torque converter.
Tue, Mar 5, 2019 1:44 AM
Nick22australia
Yeah we are thinking it was probably damaged being installed, a speedy sleeve was put on the shaft so might have have been damaged it doing that
Tue, Mar 5, 2019 6:04 AM
Nick22australia
Bad scavenge pump
[quote="Old Magnet"]On the rough shifting, yes there is a modulating relief valve that controls that.
Bad scavenge pump
Excessive leakage inside the torque converter.[/quote]
Thanks for all that
I thought the pump drive on these was lubricated via the engine oil system and was separated from the flywheel/torque divider housing?
All the valving you speak of is in the transmission control valve I’d imagine?
Tue, Mar 5, 2019 6:11 AM
Bad scavenge pump
Thanks for all that
[quote="Nick22australia"]Thanks for all that
All the valving you speak of is in the transmission control valve I’d imagine?[/quote]
You are correct (my bad), the transmission pump is driven off the engine power take off which is separate from the flywheel/torque divider housing so pump leakage could wind up in the engine sump.
Yes, valving mentioned is part of the transmission control.
Tue, Mar 5, 2019 7:03 AM
djcat
Send a private message to djcat
Not sure how you fitted a speedi-sleeve to the pump shaft as the diameter becomes too big to go through the white metal bearing.
The seal needs to be fitted with the lip facing out as there is suction behind the seal which makes it seal on the shaft.
It does take much groove wear on the shaft to make them leak.
If the t/c hsg is becoming flooded to the extent of oil passing through the engine rear seal ( large steel piston ring ) then I would imagine you would be having trans over heating issues also as the t/c would be "thrashing " at lot more oil than usual.
Might pay to check P1,P2 and the initial pressures also. I came across a bad modulating valve on a D9H once. Swapped it with one from a D8k ( same valve ) and all was good.
Good Luck
Cheers djcat.
Tue, Mar 5, 2019 7:25 AM
Reply to djcat:
Good Luck
Cheers djcat.
Are you actually seeing a drop in the transmission oil level? On the other side of the transmission pump drive would be the hydraulic pump for a dozer blade, ripper etc. That could also be a source of fluid getting into the engine.
As for the speedy-sleeve it would need to be installed from the splined shaft end of an assembled pump. I don't see any problem with doing that until it's time to disassemble.
Tue, Mar 5, 2019 10:08 AM
Nick22australia
Reply to djcat:
Good Luck
Cheers djcat.
[quote="djcat"]Not sure how you fitted a speedi-sleeve to the pump shaft as the diameter becomes too big to go through the white metal bearing.
Good Luck
Cheers djcat.[/quote]
Yeah I’m not sure what the go was with the trans pump, I didn’t rebuild it but they said it wasn’t straight forward anyway- something along the lines of what you said above with the bearing, I think they had to fit the sleeve once it was through the bearing or whatever so still might be giving some trouble if it was damaged in the reassembly.
The t/c isn’t getting hot from what I’m told but it’s the first job since having new components so could require some investigating yet, not sure if the scavenge pump was renewed by the old bloke that does the work for our family friend who owns the dozer
Wed, Mar 6, 2019 5:49 AM
Nick22australia
[quote="Old Magnet"]Are you actually seeing a drop in the transmission oil level? On the other side of the transmission pump drive would be the hydraulic pump for a dozer blade, ripper etc. That could also be a source of fluid getting into the engine.
As for the speedy-sleeve it would need to be installed from the splined shaft end of an assembled pump. I don't see any problem with doing that until it's time to disassemble.[/quote]
Yeah the trans is getting low and the engine getting high, my uncle has just been draining and resetting the levels daily.
Yeah I’m told now the sleeve was installed once the pump was assembled.
as to the direction of the seal- facing outward toward the pump drive, I’d like to know now which way around they installed it
Wed, Mar 6, 2019 5:58 AM
