D8h valve lfter guide very worn
Showing 1 to 10 of 11 results
au7edd
Send a private message to au7edd
Hello, i'm back with the 8h. Number 4 cylinder's valve lifter guides have been moving in the block. So much that it has allowed one of the pushrods to wear on the compression release shaft and break. Is there an solution to this or is the block unserviceable?
D8h 46A 21427
Mon, Oct 2, 2017 4:06 PM
Thank you received: 39
About the only recovery I can think of is to bush the block back to original size.
Tue, Oct 3, 2017 10:49 PM
au7edd
Have you seen that done? Was it successfull?
Wed, Oct 4, 2017 2:39 AM
Reply to au7edd:
No, I have not actually seen it done but I don't see why it couldn't be successfull.
Wed, Oct 4, 2017 12:43 PM
Lance Jones
Yes this type of repair is successful. We have done them before. Cat make a sleeve to do the job. They even had tooling to repair them in chassis. Good luck in finding a dealer that would have it though. Last one We did the block was stripped for a rebuild and had a machine shop do the repair.
I will try and find the part number if you want it.
Where is Eddy when you need him.LOL . I'm sure he would have come across this before. LJ
Thu, Oct 5, 2017 3:25 PM
au7edd
Reply to Lance Jones:
thanks for the info.much appreciated. i found it hard to believe that a block would be discarded because of this.
A part number would be a big help. Finding someone with the tools and the knowledge will be the hard part.
Is the sleeve pressed in or is it welded?
Sun, Oct 8, 2017 5:33 PM
Reply to au7edd:
What little I recall about the procedure is that the bushings were press fit.
Sun, Oct 8, 2017 11:02 PM
djcat
Send a private message to djcat
The part number for the repair sleeve in question is a 5P6513.
Check the cam lobes on the associated cylinder.
Good Luck.
Cheers djcat
Wed, Oct 11, 2017 4:49 PM
Reply to djcat:
Good Luck.
Cheers djcat
Anybody got information on the tooling and process involved????
Wed, Oct 11, 2017 10:38 PM
djcat
There is a special instruction sheet associated with this repair but my copy is very poor. The tool group used is a 5P6512.
Cheers djcat
Thu, Oct 12, 2017 4:14 AM
Reply to djcat:
Cheers djcat
[quote="djcat"]There is a special instruction sheet associated with this repair but my copy is very poor. The tool group used is a 5P6512.
Cheers djcat[/quote]
Can you provide/read the form number on the instruction sheet?
Thu, Oct 12, 2017 9:56 AM
