D8H Pony Removal
D8H Pony Removal
Showing 1 to 6 of 6 results
mlauck
Send a private message to mlauck
Hello all. I have a D8H 46A. Have owned it for 3 years now and I am sick of fighting with the pony motor. I went and bought a starter with the conversion plate and the rest of the electrical that I need (24v alternator, switch etc...) and want to go that route. I have a service manual, and it says I need to drain the torque converter before I pull the pony off. Do I really need to do this? Because taking off and putting back on the rear stump pan to get to the drain will make for a whole lot of grunt work.
Thanks all.
Sat, Oct 6, 2018 6:54 AM
Better fix the pony, I've had a pony motor on a D7E for 52 years and not one problem! Rebuilt once and just done minor maintenance, points, plugs, oil changes etc. I you understand it, run it properly and take care of it, it will always be dependable.
Sat, Oct 6, 2018 7:17 AM
Wombat
Donor
Don't know why you would have to drain the Torque Converter housing to remove a pilot motor and fit an electric starter, if the oil in it is that high you have major problems with your Torque Converter or scavenge pump, should only be a small amount of oil in bottom of housing.
I had a 270 D8H that had been converted over to 24v electric start, PC chambers, glow plugs etc. Was a delight to use compared to the first D8H I had with a Pilot Motor. You do need to have good batteries, if it is a regularly used tractor definitely the way to go, however if it is very infrequently used, battery life and charge could be an issue.
Wombat
Sat, Oct 6, 2018 9:01 AM
catskinner
Reply to Wombat:
Wombat
Nothing wrong with pony motor if you keep it in shape. Ran one on a D7 6T for 12 years and it worked good.catskinner
Sat, Oct 6, 2018 9:57 AM
catsilver
Reply to catskinner:
What Wombat says is spot-on, and if you don't fit glow plugs and use them well, you will spend a lot of time struggling with flat batteries.
Sat, Oct 6, 2018 1:57 PM
tctractors
Reply to catsilver:
You only need to drain down the Torque case if you are going to change the starting drive ring gear to straight cut teeth for a standard starter motor to be used, as already said pre chambers that take heater plugs and wire rail will also be needed, to do a full job can take near a week of work, some years ago it was a common task for myself to undertake, I hope things go well for you. tctractors
Sun, Oct 7, 2018 3:09 AM
mlauck
Reply to tctractors:
Thanks for the info everyone!
Mon, Oct 8, 2018 4:19 AM
Newby Hall Tractor Fest
