D8H Hydraulic hard nose hydraulic line route help needed
ld8h
Send a private message to ld8h
Hi haven't been here a in quite a while. Seems like there was a help needed forum at one time. Anyway I was wondering if somone could help me with the routing of the high pressure lines on an early d8h. Does the hard line go over the cross member by the starter? Been trying to figure it out having a real hard time. Thank in advance loren.
D8H 46A5893, D3c, Kubota Kh-191, Bobcat 963G, Old White Dump truck. 1967 Lincoln welder.
Diesel Generators
Wed, Sep 18, 2013 9:19 AM
Thank you received: 19
What are the tractor and hydraulic system s/n's
Wed, Sep 18, 2013 9:50 AM
bluox
id8h
The hyd lines go on the right side of the motor.
Good luck
Bob
Wed, Sep 18, 2013 6:44 PM
ld8h
Reply to bluox:
id8h
Good luck
Bob
Hi Bob thanks will try right side of motor
Diesel Generators
Mon, Sep 30, 2013 8:22 AM
