D8H head torque specs
brianscathouse
Send a private message to brianscathouse
Can anyone tell me the cylinder head torque specs fora 1973 D8. Just replaced front head gasket. Machine serial is 46a33087. Thanks for any help.
Wed, Oct 10, 2012 12:02 AM
bruce oz
Thank you received: 22
hello brianscathouse,i have the specs for heads on the 46a 12000? up ,i am sure if they changed for your serial number but i can post them if you want them ,bruce oz
Thu, Oct 11, 2012 4:44 AM
Thank you received: 33
Reply to bruce oz:
Hi Brian,
OM and I posted the 1970's specs on your other thread yesterday.
Late D8H Head Torque
Hi Brian,
below are specs dated Feb 70.
The thread lubricant mentioned in the chart is critical to achieving correct stud stretch/clamping force, to help clamp the head firmly and prevent gasket etc. failures.
Hope this helps.
Eddie B. Attached Thumbnails
Thu, Oct 11, 2012 6:46 AM
djcat
Send a private message to djcat
Reply to edb:
Hi Brian,
Hi Brian,
Hope this helps.
I assume that you don't have a field instalation that converted the counter bore block to a spacerplate one.Your serial number is rather high and I have seen high serial numbered H'S with the spacer plate block. Different torque specs are used for the later blocks.
Cheers djcat
Thu, Oct 11, 2012 10:30 AM
