d8h blade cylinder pivot joints
Showing 1 to 10 of 10 results
ncfarm
Send a private message to ncfarm
this is a pic of the lift cylinder upper pivot. is there a bushing that will take up all the slack in the pin joint area? i know there is what looks like a wear bushing already there but it sure is sloopy. will i have to weld up the pins on the support members? thanks
Thu, Aug 3, 2017 9:23 AM
Thank you received: 50
Should be bearings on the cylinder trunion and bearings in the yoke.
Thu, Aug 3, 2017 11:36 AM
Casey Root
For the D6C of the 1960s vintage, Cat used a crankshaft or connecting rod bearing insert for that purpose. That is what I used in my "6" after we had to build the ram ears back to a standard size.
Thu, Aug 3, 2017 12:17 PM
Reply to Casey Root:
Funny how they never see that grease fitting and let things just wear out. Oh well, like the old Caterpillar film "It's Up To You"
Thu, Aug 3, 2017 10:32 PM
The blade s/n would be helpful.
Thu, Aug 3, 2017 11:00 PM
That cylinder trunnion is shot! it wont hold a new bearing. The thick bearing is supposed to be pressed or shrunk on.
Fri, Aug 4, 2017 2:36 AM
ncfarm
is there a spec measurement for the yoke i need to get back too? part number for the bearings? my part book doesnt cover it.
old magnet where is the serial plate for the blade? i know the machine serial is readable. will that help, also have some more pics of the whole machine just not at my home pc rt now, sorry
many thanks Ty
Fri, Aug 4, 2017 8:46 AM
Reply to ncfarm:
many thanks Ty
Usual place for the s/n is the right hand upper rear side of the mold board. If no tag look for rivet holes and scratch around in the paint. Number is often stamped there.
Most likely a 28Exxxx straight blade or 29Exxxx angle blade. Early cylinders did not have bushings on the cylinder trunion, later ones did.
Yoke bearings are a 3J2217 (8 required)
Yoke bearings were only used in early cylinders so it looks like your lift cylinder trunions do not have the later bearings.
Fri, Aug 4, 2017 9:27 AM
bluox
Thank you received: 12
I think that bearing that is missing is a 5J 1192, in classic parts a 374-8355.
Bob
Fri, Aug 4, 2017 12:31 PM
Reply to bluox:
Bob
My parts book shows a 3J2189 lift cylinder in type 1, 2, 3, and 4 without trunion bearings before you get to a 5J1243 lift cylinder with the 5J1192 trunion bearings.
Fri, Aug 4, 2017 10:13 PM
catskinner
I set up the funeral tent for funerals at the cemetery's. The guy that digs a lot of the holes for us has a loader tractor backhoe. When ever he dumps a load of dirt to fill the grave up, as he is tipping the bucket, it squeals like crazy. His helper was along one day and I commented about that that it needs greasing, probably need to pull the pins out and drill the dirt out of the holes so the grease can get thru, his helper commented " to much grease, in the tube. I had never heard it explained that way before, but he was right. catskinner
Sat, Aug 5, 2017 8:10 AM
