D8h 36a opinion wanted
razz
Send a private message to razz
I have bought a D8h it is almost perfect in every way except the track pads. It has 26 inch pads. Would you put 26 inch pads on again ore 24 inch pads. seems the 24 are more common. This tractor has no blade I am going to pull My cat 435 scraper.
The scraper cuts 9.6 the cat is 9.3 with the 26 inch pads now. thanks Razz.
Mon, Dec 5, 2011 6:21 AM
Old 3T lover
Are the pins/bushings and rails worth a new set of shoes? Have you thought of welding on grouser bars? Are you buying a used set of tracks with 24" shoes?
22/24" shoes should do just fine for pulling a scraper.
Mon, Dec 5, 2011 7:27 AM
Reply to Old 3T lover:
In general it is advisable to keep the track shoes inside the scraper cut so that they are not riding on the berms.....so it would seem your 24 in. option would be preferred.
Mon, Dec 5, 2011 7:59 AM
razz
The cat has all new undercarriage except they used the old pads that have been built up some time ago about 2 inch bar height some pads have chunks out and the overlap is shot. Razz.
Mon, Dec 5, 2011 9:47 AM
