D8h
JGC74
Send a private message to JGC74
What year was this D8H manufactured? SN 10345
Sun, May 6, 2007 6:26 AM
rusted
Send a private message to rusted
46A 10345 would be a 1965 build.
Sun, May 6, 2007 6:32 AM
rusted
Reply to rusted:
I guess you mean this one.....http://cgi.ebay.com.au/Caterpillar-D8H-46A-Bulldozer_W0QQitemZ160114010309QQihZ006QQcategoryZ97121QQrdZ1QQcmdZViewItem
Looks pretty straight for an early H; pity they didn't raise the blade so it could be seen how far the tracks are adjusted out.
Sun, May 6, 2007 4:13 PM
catsilver
Reply to rusted:
Looks like a very straight machine to me, but allow for new U/C, the rollers and rails look to be worn out, count the links, there may be one short!
Mon, May 7, 2007 4:50 AM
Reply to catsilver:
I thought SALT rails usually were worn out externally needing a P&B turn because of sprocket wear or rail height too low instead of worn internally and track adjusters extended out to max.
Mon, May 7, 2007 6:41 AM
catsilver
As I said, take a closer look, SALT bushes are turned because they are worn and there is life left in the rest of the track. We are assuming these are SALT chains? They may be standard sealed or have had a turn and not been re--sealed, either way, I see worn out top rollers, 'thin' rails, bottom roller flanges striking the pin bosses, and possibly, a good gap betwen the pads. It needs a good coat of looking at before buying, to factor in the value of undercarraige left in it.
Mon, May 7, 2007 4:12 PM
