D8800 liner protrusion.
D74T
Send a private message to D74T
Does anyone know what the specifications are on the cylinder liner protrusion above the deck on a D8800 Cat D7 Diesel engine?
Fri, Aug 21, 2026 4:38 AM
ChrisE
Thank you received: 41
Most engines run at 1 to 4 thou with no more than 2 thou difference between sleeves next to each other. Hope this helps.
Fri, Aug 21, 2026 1:14 PM
D74T
Thanks.
Fri, Aug 21, 2026 8:18 PM
