D8800 Fuel filter
D8800 Fuel filter
Lance Loehr
Send a private message to Lance Loehr
I am getting ready to replace the fuel filter on my D7 3T D8800 and I would like to know if the filter tower is under pressure, or any springs are going to fly out when I remove the cap. Also is there any secrets to replacing the filter. I normally would never ask things like this but this engine is a 1948 and I can buy very little from the local parts store. Also after I get the filter replaced is there a special way to bleed the system, or is it like others where you simply crack a line until fuel comes out. I would appreciate any, and all advise you can give me.
Thanks,
Lance
Thu, Oct 1, 2015 9:43 PM
johan7
There are no frogs that might jump out .
Take the basis with the 6 filters out of the housing . Did you drain the housing ?
If so , refill the housing with clean fuel before placing the new filters , this will reduce the time to fill and bleed the housing by rotating the engine .
TAKE CARE OF THE SPRING HOLDERS THAT HOLD THE FILTERS ON THE BASIS , THEY ARE FRAGILE !!!!!!!!!!
If you refill the housing that there will some fuel overflow , you hardly have to bleed the system
succes , johan7
Fri, Oct 2, 2015 9:37 PM
Lance Loehr
Reply to johan7:
succes , johan7
Thank you I will get them changed. Thanks so much for the info.
Lance
Sat, Oct 3, 2015 7:48 PM
Old 3T lover
Reply to johan7:
succes , johan7
[quote="johan7"]There are no frogs that might jump out .
succes , johan7[/quote]Every 3T I ever owned had already had the 6 filter arrangement changed to 4 filters.....short 2 filter stick made it easier to change filters.
So, if you come up with only 4 filters in there, don't worry about it.
Sat, Oct 3, 2015 8:22 PM
wimmera farmer
Reply to Old 3T lover:
Don't forget to clean out the bottom of the housing. Have seen them with so much crud they would not leak a drop when the drain plug is removed. Some models are a very difficult shape to clean properly.
cheers WF
Sun, Oct 4, 2015 4:55 AM
Lance Loehr
Reply to wimmera farmer:
cheers WF
I opened the filter housing up and sure enough I only found four filters. Surprisingly the filters, and housing were pretty clean. Now all I to do is bleed the system and see if it will start.
I appreciate all the information.
Lance
Mon, Oct 5, 2015 10:46 PM
Newby Hall Tractor Fest
