D8800 engine pony motor clutch stuck.
tracker
Send a private message to tracker
Our 1946 D8800 runs our 1889 sawmill. All runs well except the pony motor clutch kicks out when the engine is trying to start. Then it is very hard to move the clutch lever back into position. What to do? Any help appreciated.
Thu, May 22, 2025 11:39 AM
gemdozer
Thank you received: 8
I think you need to adjusted the sleeve latch pinion
Thu, May 22, 2025 4:52 PM
| Hartley - South Australia
Newby Hall Tractor Fest
