D8800
ruakina cat
Send a private message to ruakina cat
Come home with this last weekend saved from the scrap yard. Father has pulled the heads off and found that we will be fitting another piston. Will be pulling the sump soon to look at the bottom end pics to come.
Thu, Oct 8, 2015 1:40 PM
chriscokid
good save, all you need now is the hood and fuel tank.
Thu, Oct 8, 2015 5:14 PM
Oil Slick
Reply to chriscokid:
Interesting trailer tire choice. Does only one axle have brakes? Got a picture of the tow vehicle and trailer together?
Thu, Oct 8, 2015 10:39 PM
Online
Thank you received: 95
Reply to Oil Slick:
Hi RC,
great save Mate.
S/No 4H 3001-up D8800 Industrial Engines came out from 1936 thru until April 5 1939, rated at up to 80HP.
Even has the elusive Bill of Materials number to tell you what the engine consist parts are, that is if The Dealer still has the old book with them in.
Our Dealer tossed the book when the BOM's came out on Microfiche--little realising that the MF's continued on from where the book ended!!!!
Enjoy it and keep us in the loop with its restoration etc.
Fri, Oct 9, 2015 5:29 AM
ruakina cat
Reply to edb:
Hi RC,
great save Mate.
Have the heads off bit hard to see in the pic but number 3 piston has lost a ring going to be a long slow job but long term gold is to use D8800 to start the D397 engine.
Sat, Oct 10, 2015 8:58 AM
ruakina cat
Reply to ruakina cat:
Pulled the sump and rolled the engine on its side removed all the other pistons to find that they are broken as well. Have a 3T engine later model looking at pulling the pistons out of that I know that they are different in skirt length.
Fri, Oct 23, 2015 12:09 PM
