D8 triplet by C@
D8 triplet by C@
Showing 1 to 10 of 12 results
§wishy
Send a private message to §wishy
[b]
Jist wunderin
Wot were they thinkn
LOL
[img]http://img189.imageshack.us/img189/9105/d8triplets.jpg[/img]
LOL
WotSayU?
cya
§wishy
HasBeen[/b]
[CENTER]🙄 - : [B]ButEyeDoSt&2BCorrected : - 😛
Ifn U Get my Drift[/b]
😮 [/CENTER]
Fri, May 20, 2011 6:11 PM
Jim Sixty
Send a private message to Jim Sixty
I'm afraid I would have to give in and side load that beast 😆
Fri, May 20, 2011 7:41 PM
B4D2
Reply to Jim Sixty:
D-24? 👍 At least there's lots of room for riders in the big tractor parade.
Sat, May 21, 2011 7:26 AM
donl4
Send a private message to donl4
Reply to B4D2:
I was wondering how the start the pony's on the center and right engines?
Don
JD40C
Sat, May 21, 2011 11:07 AM
Walt D7-3T
Send a private message to Walt D7-3T
Reply to donl4:
Yes, I was wondering the same thing. I have even wondered about the twin D8 photo I have seen. My assumption is that there is some way thay are connected so you would start the left most and then let that D8 engine start the two other diesels.
BUT, I am curious.:noidea::noidea:
Sat, May 21, 2011 2:33 PM
Reply to Walt D7-3T:
Start one engine, then disengage steering clutches to start the other engines through the transmissions??????
All the controls need to be tied together somehow for one operator to control.
Sat, May 21, 2011 6:01 PM
Thank you received: 140
Reply to drujinin:
Hi, Skwishy.
Have you been having another bout of Imaginitis?????????????? Or did you just git bored and decide to have a late April Fool's joke?
I have never seen the control deck of any of the 'siamesed' D8's that Buster Peterson built BUT I would be very surprised if that worthy gentleman did not have all that stuff figured out. For those of you who aren't quite intimately familiar with the 2U D8's, there would be adequate space to reach between the two engines to start the pony motor on the right-hand diesel, engage the pinion and clutch and access the decompressor lever.
If the gas cock for the right-hand engine was left in the original position, THAT might be a problem but I suspect that Buster would have figured that one out too.
As mentioned above, I have never seen the control deck of any of the original 'siamesed' D8's but I suspect that there would have been only TWO steering levers and TWO brake pedals. Why woodjyer want any more when yer only had two tracks anyway?
If it were me building these jiggers, I think I would have used separate levers for each master clutch situated close enough to be operated individually or together and maybe have some sort of dis-engageable interlock on the transmission controls so that they could be changed independently or together. There are some inherent advantages to being able to contra-rotate crawler tracks.
Now three uv 'em side by side? THAT might be a whole diff'rent ball game. R U gonna clue us up, Skwishy? Or R U just gonna leave us dangling by our starboard 'curiosities'?
Good 'artwork' though and an interesting concept. Thanks for sharing.
Sat, May 21, 2011 6:55 PM
ronm
Hi, Skwishy.
On the Smokstak board, there's a character that pops up once in a while, called Ben Hadd...I think he may have an Aussie cousin...😆
Sat, May 21, 2011 10:13 PM
Tad Wicks
Reply to ronm:
Squishy, The first thing that pops into mind when looking at back view of this creation is how it sounds like some of the gals you been chasing.😆😆 As Deas would say it " that jigger is kinda broad across the beam M8'' Tad
Sat, May 21, 2011 11:18 PM
Kelly
Hi, Skwishy.
[quote] Deas Plant.;I have never seen the control deck of any of the 'siamesed' D8's that Buster Peterson built BUT I would be very surprised if that worthy gentleman did not have all that stuff figured out.
If it were me building these jiggers, I think I would have used separate levers for each master clutch situated close enough to be operated individually or together and maybe have some sort of dis-engageable interlock on the transmission controls so that they could be changed independently or together. There are some inherent advantages to being able to contra-rotate crawler tracks.[/quote]
Deas Plant,
There’s the way it was on the "Siamese D8's". The control system consisted of two gear shift levers, two steering clutch levers, one master clutch lever and two throttles mounted on the left arm rest. The throttles could be used to give gradual power turns as each engine drove one track only. The standard steering clutches could be used for sharp turns or a pivot turn could be executed by having one transmission in reverse and the other in a forward gear.
Kelly
Sun, May 22, 2011 8:51 AM
Reply to Kelly:
Deas Plant,
Kelly
Hi, Kelly.
Thanks for clearing that up. So I was not far off the mark. I had already figured out that the throttles could probably be used for gradual turns and there would only be two steering clutch levers and two brake pedals. I am not terribly surprised to find that the transmissions could be controlled separately as there are some advantages inherent in being able to contra-rotate the tracks for manoeverability, especially in bigger machines, and to being able to drive one track slower or faster than the other - with visions of the Euclid TC12.
I just plain did not know whether there would have been one master clutch lever controlling both master clutches or if each had its own control lever. Do you know if there was ever any problem synchronising the engagements of the two clutches with only one lever? Just wondering. I imagine that the adjustments on each would have needed to be pretty close to identical pressure or one may have engaged before the other - or slipped before the other, as the case may be.
Sun, May 22, 2011 3:26 PM
