D8 trackframe broken..
Showing 1 to 10 of 14 results
Roydsracing
Send a private message to Roydsracing
Anyone ever see one break like this? When I got the machine the rock gaurds were welded on. The one on this side soon broke at the end tou see here. I've kept an eye on it for about 4 years then after makin money with it this summer (about 400 hrs) it started to crack on up the track frame. I'm going to try to fix it in place. Any advice would be great.
Little background on the tractor, it's a 14a dry deck ex logging (very abused) machine. The right side track frame has a plate welded on the bottem to strengthen the inner dead axle support. Left side does not have this plate.
LeRoy
Wed, Jan 7, 2009 5:01 AM
Thank you received: 20
Wow, that looks nasty.....it isn't just about "gluing" it back together......the challenge will be aligning the track frame so there is a chance of keeping the rails straight and parallel.
Wed, Jan 7, 2009 9:48 AM
OzDozer
Yep, common problem on old tractors with high hours and that have been worked hard on rock. The older channel-type track frames are more prone to this problem than the later boxed style (the boxed-style was supposed to be the solution to track frame cracking) .. but the boxed ones crack, too. I've fixed numerous broken D6 and D7 boxed-style frames in this exact area.
Just jack up the frame .. align the broken sections with a string line .. vee out the crack .. practise your very best 7018 vertical weld .. 😄 .. and then grind the weld, and fishplate the area with a 12"-15" long, 1/2" thick plate, that has tapered ends.
Run the welds on the fishplate down the taper, but then run them out parallel, so they don't join. This eliminates stress areas and any further cracking.
The alignment problem isn't something to get too concerned about .. you can get alignment reasonably accurate using a string line .. then adjust idler shims/sprocket hub adjustment to align the track components.
You can get real perfectionist about alignment, when rejoining these two broken sections .. then you find that the front two extensions of the frame, each side of the idler, are twisted, anyway .. and creating more misalignment than you'd get with a misaligned join in this area.
If ya wanna do it factory-style, you'd pull the whole frame, strip it .. then lay it out on a jig, and measure every dimension, in every plane, to make it perfect. That might be O.K. for a company D11, but you're operating an old wreck, compared to most company operations.
Fixing old dozers isn't a perfect science, you gotta do what you can, generally under some adverse conditions, and within a very tight budget.
Wed, Jan 7, 2009 10:06 AM
Reply to OzDozer:
To me the bigger problem is what's going on with the inner track frame brace.....which is now carrying (bending) with the load. Good chance you will need to cut the diagonal brace loose from the frame, repair the track frame rail then weld back the brace when you've got it reasonably aligned.
Wed, Jan 7, 2009 10:30 AM
jmvmopar
Would have been nice to fix that at the first sign of cracking. I agree with Oz I'd be jacking and trying to weld that best I could. Then go about adjusting the tracks. What ever is bent is going to be near impossible to straighten. And with such a beat machine you could make more problems. Weld it up and see what happens what do you have to loose. Good luck
Wed, Jan 7, 2009 11:33 AM
OzDozer
Reply to jmvmopar:
I don't see any problem with the track frame inner diagonal brace. The inner brace is there to keep the track frames aligned in a horizontal plane and parallel. There may be a slight twisting action being applied to the inner brace, but nothing that it can't withstand.
The wear in the inner brace bearing will usually compensate for any slight twisting. If a lot of old tractor owners got the measuring tape out, and accurately measured track frame misalignment (in the vertical plane, the horizontal plane, and for parallel), they'd likely be totally appalled at what they find .. at what they never suspected .. but which is still performing O.K.
Track frames are notorious for regular misalignment. Not 6 mths after I took delivery of my new D6C's, Cat issued a re-design/upgrade order, involving reinforcing patches for the D6C inner braces .. which consisted of plating the entire length of the braces with a huge "Y"-shaped fishplate, to strengthen them.
Wed, Jan 7, 2009 12:37 PM
chriscokid
Reply to OzDozer:
I am always inpressed with Old Magnet, OzDozer, and SJ there is not much that you guys have not done or seen. thanks for adding to the BB whenever possible.
Wed, Jan 7, 2009 10:26 PM
Reply to chriscokid:
Horizontal and parallel alignment is what I'm referring to. The shims on the final hub and front idler will only allow side movement.....doesn't do a thing if you have a "dog tracking" undercarriage. See what you can get jacking the frame, but if you can't get the dog tracking or twist out of the assembly I'd still cut the inner arm loose (maybe closer to the inner bearing journal) and re weld.
Depends on how bad it is. Seen lots of "cobbled up" undercarriage.....it all does work for a while.
Wed, Jan 7, 2009 10:50 PM
Roydsracing
Hi Guys
Thanks for all the responses. Lots of things I didn't think to do. One thing I'm still unclear about is if this section of the track frame is hollow or is it a c-channel. It appears to be attached to a big cast piece going around the front of the sprocket. I've got my wife pressure washing the machine today so I'll have a better look tonight after work. I walked it about a mile uphill to my shop with my brother watching the crack. It opened and closed going over any bump. When I parked it I got the crack to close up and the track frame is straight by measuring the clearance from the idler end to the frame. Same on both sides and same on the other 14a I have. So I'll string it and weld it.
I'll take pictures of the progress.
LeRoy
Wed, Jan 7, 2009 11:35 PM
Reply to Roydsracing:
Hi Guys
LeRoy
In checking the parts book it appears the broken section is boxed with a short fish plate blocking the ends. The break is at the weakest point...between the rebound spring buttress and the bearing block.
Thu, Jan 8, 2009 12:01 AM
OzDozer
The track frame main members on the D8 14A are full-length box-section .. and the section that has cracked has a "T" shaped buttress welded to the inner part of the box section. This "T" shaped buttress is part of the bracing that holds the two main members together, and which strengthens them.
Going on the position of the crack in your pic, I'd say the buttress is cracked right through, too .. 😞
This isn't the end of the world .. just more work than it initially appears. You'll need to weld the two vertical cracks, inner and outer, the topside and underside of the track frame, plus the crack in the buttress plate .. then plate where you can. If you get a good weld on the inner cracks, just the one fishplate on the outside of the track frame should be adequate strengthening.
Track frame - parts diagram .. http://img211.imageshack.us/img211/7162/d814atrackframedx9.jpg
Thu, Jan 8, 2009 11:53 AM
