D8 Shipping Weight
D8 Shipping Weight
Farmall Man
Send a private message to Farmall Man
I recently purchased a D8 at an auction over in Illinois and i am having trouble coming up with a weight on the Dozer to get it hauled back here to Central Indiana....not to mention that the pony motor won't start but that will be the subject of another thread!!
I have found some info indicating an approx weight of 36,500lbs, but i am assuming that it is the approx weight of the tractor itself....can anyone help with a closer weight of it with a ROPS and 11'6" cable lift blade, believe it to be a '55-'58 model based upon the design of the cable lift....
Also if anyone can give me an exact year i would also appreciate it....serial number is 14A1-702
Mon, Dec 29, 2008 10:47 PM
Oil Slick
FM, depending upon optional equipment it should weight pretty close to 53,000lbs. Good luck.
Mon, Dec 29, 2008 11:19 PM
Thank you received: 50
Reply to Oil Slick:
Bare tractor 40,000 lbs
Straight blade with rear CCU 6,355 lbs
Year of build is 1955
Mon, Dec 29, 2008 11:40 PM
OzDozer
Farmall Man - We need a little more info for a degree of accuracy. Is it a front CCU or rear CCU? Is the blade an angle blade, staright blade or U-blade?
Your blade width doesn't gell .. the 8A (angle) blade is 13' 7" wide, the 8S (straight) blade is 12' 1" wide, and the 8U (U-blade) is 11' 11" wide.
Is the canopy a proper heavy duty ROPS with sweeps? .. or just a tree-resisting FOPS canopy? You also need to factor in any additional equipment such as roller or other guards, dirt in the belly pans, and the condition of the undercarriage.
Mikes figure is close to the mark, and your tractor could even run a little higher, depending on what is fitted by way of attachments.
Tue, Dec 30, 2008 7:40 AM
firpitch
Send a private message to firpitch
Reply to OzDozer:
FM, I have weighed my late model 2U with U-blade, full ROPS, belly pan, rock gaurds, front CCU, Hyster D8L drum, and what ever dirt accumulation right near 30Ton. Hope that helps. firpitch
Fri, Jan 2, 2009 12:22 AM
SSsssteamer
Send a private message to SSsssteamer
Reply to firpitch:
My D8 14A with hydraulic blade, winch, belly pan, rops weighs over 50,000 pounds (without dirt added). On it's last trip, in order to keep the weigh down, the blade arrived a week later. I didn't get the weight on the blade (13' 6" wide) by it's self.
Sat, Jan 3, 2009 1:31 PM
Farmall Man
Reply to SSsssteamer:
Thanks for all the info, it is a straight blade with rear CCU...and it has a ROPS but i am unsure of what style, doesn't have the tree sweeps i know that forsure!!! Here is a pic of the ole gal from the auction day....
Tue, Jan 6, 2009 7:24 AM
OzDozer
Reply to Farmall Man:
D8E tractor operating weight .. 40,430 lbs ..
Rear #29 CCU ......................... 1,990 lbs ..
#8S blade (12' 1" wide) ........... 6,355 lbs ..
ROPS ....................................... 1,250 lbs (approx) ..
TOTAL .................................... 50,025 lbs (approx) ..
To be accurate, that canopy wouldn't pass muster as a ROPS. The definition of a ROPS is a structure that is supported via some serious-size mountings on the tractor chassis, and which can withstand tractor rollover without serious deformation. The style of canopy in your pic is defined as a FOPS (Falling Object Protection Structure), and is designed to protect the operator from falling limbs and small trees. A direct hit from a big tree would probably make a mess of it .. as well as the operator.
Tue, Jan 6, 2009 7:47 AM
Reply to OzDozer:
Here's another run....all from parts books.
Bare tractor 39,995 lbs operating weight.
#29 ccu......2,305 lbs (including adapter group)
44C-1193-up straight blade (11ft-3-1/2 in. wide)
(Equipped for use with rear ccu).....6,355 lbs.
Total....48,655 ibs + ROPS ++++
50,000 lbs seems like a good approximate number unless it's loaded with goodies😊 😊 The original 53,000 is a good number also.
Tue, Jan 6, 2009 10:30 AM
