D8 engine Stuck 14a
D8 engine Stuck 14a
Showing 1 to 10 of 28 results
4x6zh itzik
Send a private message to 4x6zh itzik
After some years standing out
Sun \ rain \ barn
And a few months in our warehouse
We try to run it
* Auxiliary engine does not move .
* After several attempts ( rotate the engine by hand not by starter)
* It turned the engine.... turns and stops....
* We removed the engine and then we found
* Magneto stuck.
Just turn ignition mechanism and stop .
Lucky we removed the engine
It is possible to see that the water caps
Rusty and leaky
Main engine does not move
For several weeks we trickling oil \ fuel Into the manifold
Yesterday it seems that the engine starts moving
I use a round crowbar on the flywheel
http://youtu.be/wOtO9S_uDPg
Itzik
Problem with unsticking engines is even though you may get the pistons moving, stuck rings may never recover.....but there is always an optimistic chance, Good luck with that one.
Sun, Aug 4, 2013 10:32 PM
[attachment=18802]#3 piston cleaned up view 2.jpg[/attachment][attachment=18803]#3 piston cleaned up first view.jpg[/attachment]Never know how it will run until you get it unstuck and run it enough to get it hot a few times. Here is one possible result of one being stuck and then unstuck. This engine was running and the tractor was working, but it was "huffing" out the crankcase breather,....... NO chance you might pour oil into it while it was running.......... and then it suddenly got a lot worse. This was what we found when we tore it down. Each cylinder had a mark where the rings had been stuck at one time.
Sun, Aug 4, 2013 11:54 PM
4x6zh itzik
Hello everyone
After a few years we went back to work on the tractor
The engine was the whole time with rust oil
Every few months trying to rotate the motor
Yesterday I opened the engine-side service doors
And that's what I found
To be continued ....
mrsmackpaul
Reply to 4x6zh itzik:
Hello everyone
HMMMMMMMMMMMMMM looks like you boys are gunna have to get fairly dirty before she's gunna go again
Paul
Sat, May 30, 2015 2:55 PM
Thank you received: 77
Reply to mrsmackpaul:
Paul
Keep working on it Itzik! You'll get there : ) Even if the rings don't work out (and they probably won't) if you actually get it to run, no matter how badly, that will encourage you to keep going. I reckon the worse it is, the bigger the challenge, the more fun. My D2 looked like that inside
Sat, May 30, 2015 6:36 PM
4x6zh itzik
So today I decided no choice
We removed the rear cylinder head
And that's what we found
I hope that now it will be possible to rotate the motor
And the piston sleeve along with the piston may be removed
old-iron-habit
[quote="4x6zh itzik"]So today I decided no choice
To be continued ....[/quote]
OUCH! At least now you know what you are dealing with. Keep up the good work and keep us posted. The tougher the job the more satisfying the sweet sound when it finally runs will be.
Sat, Jun 6, 2015 12:24 AM
4x6zh itzik
Reply to old-iron-habit:
Continue following the rust
No. 3 piston also is full of water
4x6zh itzik
Continue slowly
No. 3 cylinder was pulled
A little patience and No. 6 pops up
Itzik
4x6zh itzik
Continue slowly
Itzik
Continue slowly
