D8 Cable Blade Lift and Serial Number Location 1948 Year?
krunch
Send a private message to krunch
What is the best way to get the blade up on a Cable Lift to get the ol' girl to the shop? Where should the tags bee on this one. Found a tag above the pony motor Product ID -- 5B8821.
Thu, Oct 6, 2011 12:20 AM
Snuffy
Send a private message to Snuffy
Not sure what you have to work with or what kind of a trailer you are loading it on. I always had a winch tractor and would load dead tractors backwards, either winch them over the beaver tail or over the front on a removable neck trailer. When your D8 is at its highest point before over centering (which ever end you are loading on) the ground will force the dozer up, stop and chain it up to the hardnose. This works if you are winching or towing with another unit, on hyd. or cable dozers. Always put a boomer in your chain holding the dozer up so when you go to remove the chain you only have to block the dozer and not lift again to remove the tension off of the chain.
Good luck, Garry
Snuffy
[SIZE=2]1937 22, 1939 D7 9G, 1950 D4 7U, 1953 D4 7U,1953 D2 5U, 1962 D7E[/SIZE]
Thu, Oct 6, 2011 2:03 AM
krunch
Reply to Snuffy:
Good luck, Garry
Thanks Gerry, that will work.
Krunch
Thu, Oct 6, 2011 9:54 PM
