D8 Brake Band Bolts
D8 Brake Band Bolts
HUNTER
Send a private message to HUNTER
Is there anything special about the brake band adjusting bolts,that a normal hex head bolt of the same size would'nt work the same?.The only thing that looks different to me,is that the bolts I took out(because they were bent),appear to have the tip rounded off where they contact the brake band,but that may be due to wear. Any thoughts??
Tue, Nov 6, 2007 3:59 AM
Thank you received: 22
What model is it?
Tue, Nov 6, 2007 8:59 AM
Are they the support bolts that are underneath the tractor and support the bands from the bottom?
I would guess a standard bolt probably doesn't have enough threads on it, but I've never removed one from any tractor to look at it. Why not thread one on down? I doubt the tip shape is real critical, it just supports the band from beneath so it doesnt sag and drag the upper sections on the brake drum when the brake is released.
Tue, Nov 6, 2007 10:04 AM
If it is the support bolts you can buy continuous thread bolts up to 6 inch long from McMaster-Carr. Choice of grade 8 square (set screw) head like original or regular hex.
Tue, Nov 6, 2007 10:28 AM
HUNTER
S/N#8R-641. Yes they are the bolts that support the brake bands from underneath.If I cant find bolts long enough with long enough threads,then I plan to make my own.
Wed, Nov 7, 2007 2:29 AM
Reply to HUNTER:
Hi Hunter,
maybe use some "allthread" and cut it to length then weld a nut on one end so as to able to adjust it without having to resort to multigrips or what ever.
I make a lot of one off bolts this way,if the weld is machined up you would hardly know the difference.
Wed, Nov 7, 2007 6:37 AM
