D8 8R engine trouble
Showing 1 to 7 of 7 results
Jeremy Williams
Send a private message to Jeremy Williams
I am starting to work on a 8R D8 that the engine is unstuck in and will turn over about 3/4 of a turn, then hits something hard and wont budge. I can roll the engine back the opposite way and it does the same thing. It doesnt get snug and stop it almost makes a ''clang'' when it stops. I have checked the valves. I tested the lifters and all seem to move, and the fuel pumps can be moved up and down. The only thing outwardly wrong that I can see on the tractor is one water pump packing nut is split. Any ideas? Thanks, Jeremy
Fri, Sep 11, 2009 8:25 AM
Thank you received: 19
Sounds like you have an obstruction or object in one of the cylinders.....could be a whole list of candidates.....rust, nests, piece of hardware, etc.
Not a good idea to force it but soaking with diesel or other solvent/penetrants might help if it's something that can be softened up.
Fri, Sep 11, 2009 8:34 AM
OzDozer
I'd check the flywheel housing and clutch area for obstructions. A lot of people on the tractor forums have often reported back with objects jamming the flywheel or clutch, when they started out with problems with an engine that would only turn a certain amount, and then lock up.
Fri, Sep 11, 2009 8:45 AM
Jeremy Williams
Reply to OzDozer:
OM I wont force it and probably start by taking a head off this weekend to see whats in the cylinders, as that was my thought.
OzDozer, I forgot to mention I have the clutch freed up and doesnt appear to be binding on anything, but I will check it this weekend and make sure before I get too far into the engine.
Thanks for the replies and will report on what I find. Thanks, Jeremy
Fri, Sep 11, 2009 9:39 AM
u-joint
Send a private message to u-joint
Reply to Jeremy Williams:
jeremy,
does this tractor have a front cable control unit? if so have you checked it
out? i also have an 8R, its not home yet. after i bought the thing i was
working on a few things making it ready for a road trip home. i started the
pony and had everything in gear warming up to start the main engine when
suddenly bang and the main stopped turning over. i killed the pony and
started looking around. underneath the tractor laid what looked like a starter
bendix. looked down from the top and sure enough, it puked the drive gear
assembly straight through the nose cone. great, how am i going to get this
beast home now! i gathered up the pieces, robbed some bendix parts from
the 3T sitting beside the 8 and brought them home. welded up the four
piece nose cone making it one piece again and everything worked. the nut
on the end of the shaft that holds the bendix secure came off. this nut you
may want to make sure is there and secure. i got lucky as the threads on the
shaft were still good, just needed a nut. you only need to worry about this
after you get your main engine to turn. hope its nothing serious, these old
8's are a great tractor in my opinion. kind of get teary eyed thinking about
them!
Fri, Sep 11, 2009 1:26 PM
Jeremy Williams
Reply to u-joint:
jeremy,
them!
U-Joint this tractor just has a rear cable control. Although I wish it had a front CCU. I will check it out anyway to make sure it is seperated when turning the engine. Jeremy
Fri, Sep 11, 2009 9:56 PM
Jeremy Williams
I found the trouble in the engine today. The #4 exhaust valve leaked water into the engine and formed a rust line down the side of the cylinder. But the good new is that I can turn the tractor over now and going to try to start it next weekend if all goes well. Thanks For the help fellas. Jeremy
Sun, Sep 13, 2009 5:09 AM
Thanks for the feed back.....rust does seem to be one of the most common reasons for stuck or obstructed pistons.....well worth a head gasket job to know and not damage anything.
Sun, Sep 13, 2009 6:46 AM
