D8 36a Diesel in the oil
Showing 1 to 9 of 9 results
Sthorpe
Send a private message to Sthorpe
Good morning, getting diesel in the oil. Thought it was the drain tube on the lift pump because it was plugged. Unplugged the line and went to change the oil. I left the drain plug out overnight and noticed the next day diesel was still dripping 24hrs later. Removed the covers on the oil pan and diesel is dripping thru the oil pump. When i drained the oil there was a significant amount of diesel. Probably a few gallons. It leaks even when the engine is off. Has anyone had this issue before and where would the diesel enter the oil pump?
Mon, Nov 2, 2026 3:58 PM
You need to change the 8B4967 fuel gallery seal. #9 in picture.
Mon, Nov 2, 2026 7:13 PM
Sthorpe
Great. Thank you! Is this fairly common on older Caterpillars?
Tue, Nov 3, 2026 2:42 AM
Yes, common to units that have the integral fuel passage between housings. Later units had external connections that would not result in internal leakage.
Tue, Nov 3, 2026 5:03 AM
d2gary
I don't have experience with the D8 or larger machines but on the D2 andD4 that I have worked on have the same o ring seal at the other end of the tube also. The one pictured is usually the one thats bad but its not a lot more work to replace both o rings since you're that far into it. It will look different from years of compression but is in fact an o ring.
Tue, Nov 3, 2026 3:30 PM
Only one seal used on these D8's 8B4967 = trade size dash 318.
Tue, Nov 3, 2026 4:19 PM
Sthorpe
Have the seal in hand. Trying to remove the injection pump. Followed the service manual. All bolts are off. Oil line disconnected. Drip lines removed and removed the bolt on the fuel injection rack. Have the injection pump supported, but it will not come out. I managed to wiggle it back and forth to get a 1/8 to 1/4 inch. It seems really stuck. It feels like the tang is pressed into the housing. Anything I’m missing? Are they supposed to come apart easily?
Thu, Nov 12, 2026 3:01 AM
Should not be a problem with the tang, nothing to hang up there. Could be hanging up on the studs requiring a straight pull.
Thu, Nov 12, 2026 3:40 PM
Thank you received: 78
Is there a nut on the inside by any chance?
Fri, Nov 13, 2026 1:05 AM
Thank you received: 94
I believe there are 7 external nuts holding the Inj. pump to the Gov. housing and 1 linkage (nut and bolt, Gov. linkage to rack connection) behind the governor housing side plate.
Unless an engine side cover plate bolt or two needs to be removed also to allow the Inj. pump to slide back far enough to disengage the mounting studs. Been too long to recall now since I worked on one.
Sat, Nov 14, 2026 2:59 AM
