D8 2U with D13000 and leaking pre-combustion chambers
phunguy1976
Send a private message to phunguy1976
Does anyone have experience pulling the pre-combustion chambers on a D13000 replacing the O-rings and brass washers and then putting the chambers back into the head.
Wed, Mar 16, 2016 3:40 AM
Done it on other engines.
If the chamber doesn't "break free" and is coming out hard, I suggest putting an impact wrench on it and rattling it back in and then out a little at a time to avoid taking all the threads out of the head. If you do, you can put in a helicoil insert.
Old style chambers has a separate "retainer" that sealed around the top of the chamber in the head. There were o-rings inside next to the PC chamber and outside next to the head. The retainer can be removed, resealed and replaced without disturbing the PC chamber itself with the correct set of tools. If you are dealing with this type and do not have compression leaking into the cooling system, I would leave the chambers alone just to avoid the possibility of damaging the threads.
Newer chambers are one piece and have only the copper washers on the bottom and the outer o-ring around the top. They must be removed to reseal the o-ring.
Wed, Mar 16, 2016 4:25 AM
The poster neglected to state that he's dealing with the early style pressed in chambers.
Wed, Mar 16, 2016 6:25 AM
Wonder if you could modify the head to use the screw-in type?
Wed, Mar 16, 2016 7:20 AM
Newby Hall Tractor Fest
