D8-2u starter
D8-2u starter
Showing 1 to 9 of 9 results
Crossed
Send a private message to Crossed
This is my first dozer and I have only had it about 8 weeks, so I am pretty green here. When I purchased it I hand cranked it several times and had no problem getting the pony motor fired up but it has become very difficult to get it started. I don't know why. It already has a starter (no battery) so I have tried to jump start it but am having no luck. The starter kicks in but is not engaging the gear. It says delco 98240 reman inertia dr 6v ccw on the starter. It turns over plenty fast just not engaging. Any ideas on what to do to solve my problem. d8 2u #17234 Thank you
Sat, Jun 7, 2014 9:50 AM
dieselfreakcjw
Send a private message to dieselfreakcjw
Sounds like some gunk on the "threads" of the bendix not letting the inertia of the motor throw it out. Or sometimes they will wedge in the retracted position if the last time it was started the engine kicked a little and threw the bendix back with force.
Caterpillar 30 PS244
International Harvester T-40
John Deere 720 Diesel
Sat, Jun 7, 2014 10:49 AM
Crossed
Reply to dieselfreakcjw:
So how do I fix that
Sat, Jun 7, 2014 10:50 AM
dieselfreakcjw
Reply to Crossed:
Just pull the starter off and clean the threads on the bendix or unjam it if it's stuck. If it sticks again replace the bendix or the whole starter.
Sat, Jun 7, 2014 11:31 AM
dick
Send a private message to dick
Crossed is talking about the pony starter, it is 6v. The gear engagement is manual with the lever that pushes the gear into the ring gear and goes on to contact the starter switch. Remove the whole starter assembly by removing 4 3/8 bolts mounting it on top of the pony clutch housing. When turned upsidedown it should be obvious what the problem is. I may have parts to fix it.
Sat, Jun 7, 2014 7:46 PM
ag-mike
Reply to dick:
take just the starter off its housing and investigate the bendix. bench check it to see if the bendix to pop out. teeth could be stripped off if not adjusted correctly when it was installed. good luck.
Sat, Jun 7, 2014 7:52 PM
Crossed
Reply to ag-mike:
It does have the lever to engage it. When looking at it you move the lever to the right towards the starter. I am guessing the bendix has to pop out to the left to engage the ring gear? Or does the ring gear move towards the starter when you move the lever?
Sat, Jun 7, 2014 8:10 PM
Crossed
Reply to Crossed:
Dick. I will check it out and hopefully wont need parts but if I do I will check with you. Thanks
Sat, Jun 7, 2014 8:33 PM
ag-mike
Reply to Crossed:
like i said, take the starter off and learn what things do when u move the lever to the right. good luck.
Sat, Jun 7, 2014 8:36 PM
Thank you received: 46
Reply to ag-mike:
I'd be on the look out for a broken bendix drive spring.
Sat, Jun 7, 2014 10:32 PM
