D8 2U oil pan gasket
ScrapingThroughTime
Send a private message to ScrapingThroughTime
I am looking for some advice on my 2U.
I need to drop the oil pan and also remove the oil filter system from the side of the block so I can clean everything out.
The parts book shows the following gaskets:
Pan gasket, rear: 1F4090
Pan gasket, front: 1F4089
Filter base to oil line manifold: 7B4034
Filter base gasket: 7B4520
I called Caterpillar this morning and they said all four gaskets are no longer available.
For those of you who have done this before, what has worked best? Should I plan on making new gaskets out of sheet gasket material, or have any of you had good luck using RTV silicone sealant in these locations?
I would rather do it right the first time while everything is apart. Any advice on gasket material, thickness, or sealant that has worked well would be appreciated.
pictures for reference.
Cat D8 (2) • Cat D7 (2) • Cat No.12 8T Grader
Gar Wood 524-S • Bucyrus Erie #68 Cable Scraper
Pushing Dirt & Pulling Steel the Old-School Way
Mon, Apr 27, 2026 5:35 PM
Thank you received: 291
My best guess is that your parts person did not add an "O" or zero to the parts number? I have been told that the old part number needs to have extra #'s? Someone help me here. Olson's Gaskets should have what you are looking for.
Mon, Apr 27, 2026 7:21 PM
brian18a
Thank you received: 70
Part numbers changed but the later numbers are also obsolete.
Tue, Apr 28, 2026 12:17 AM
ScrapingThroughTime
Thank you Juiceman and Brian, I appreciate the help.
I did reach out to Olson Gasket to see if they can make something up for me. I was also able to get the gasket between the two oil pan sections from Caterpillar, so that at least takes care of part of it.
If I strike out on the rest, I will plan on making the remaining gaskets myself.
Tue, Apr 28, 2026 12:11 PM
D6Joe
Send a private message to D6Joe
Reply to ScrapingThroughTime:
I’m a little late to the conversation, but I might have the gaskets you need. I have a 7H1997 and a 6L5311. And a pair of large square gaskets with 10 bolt holes in them. I’m sure they were for a later 2u I used to have.
Sat, May 23, 2026 11:55 PM
