D8-2u leaking trans
D8-2u leaking trans
Showing 1 to 10 of 10 results
TIREDDOZER
Send a private message to TIREDDOZER
I have a cat D8-2u dozer that has a MAJOR leak in the trans. I can get about 15minutes to 30 minutes before the trans starts howling. It appears it to be leaking out the front input shaft of trans. My Brother seems to think it leaks out the right rear drive sprocket, and the finals. To tear into this is a really huge undertaking. I have good mechanical skills and have a newer 580 backhoe to use as a hoist. Also this tractor has never had 3rd gear working. It won't go into gear at all, tried everything. Seems like the shaft is froze up. Just grinds when at idle with clutch pushed all the way forward. Question is can this (oil leak) be fixed through the top of the trans (input shaft) or am I going to have to tear the back half of the tractor apart to replace the seals. And if it comes to that I might as well replace all final drives seals and trans seals. WHAT A BIG JOB!!!!!!!!!!! Any ideas????
Tue, Sep 9, 2014 1:01 AM
Paso Bob
In my experience, usually if a seal is leaking it is caused by a bearing gone bad.
Tue, Sep 9, 2014 8:57 AM
bullcrk,6
Send a private message to bullcrk,6
Reply to Paso Bob:
what is serial # earlier 2Us have a one piece shaft that means it needs to be removed from the tractor to change seal, you do not need to touch the finals for this but it is a bit of a project, a service book will give you step by step. midway threw the 2Us they changed the shaft and the flange can be removed to change the seal without taking trans apart
Tue, Sep 9, 2014 10:00 AM
TIREDDOZER
Reply to bullcrk,6:
The tractor ser# 199335 I Believe the oil leak is the front input shaft of the trans as most of the oil is coming from the front of the trans. Does anybody know if I can still buy the seals? Not looking forward to doing this job. I remember replacing the clutch and thermoids and it was a big job. The dozer does not have a canopy so its hard to remove those heavy parts. Also I know the bearings are good shape, No slop or noises.
THANKS STEVE
Wed, Sep 10, 2014 10:18 PM
Thank you received: 93
Reply to TIREDDOZER:
THANKS STEVE
Service Bulletin (Track Type Tractors) Feb 21 1955, tells us that the two piece upper shaft was fitted standard from 13A 3234 and up and was adaptable to the D8 2U 21513 and up, and earlier 13A 1 and up tractors, also to 2U 5307 and up tractors that have been field fitted with oil clutches.
Thu, Sep 11, 2014 9:28 AM
Reply to edb:
Check that s/n again. They only built to 23,527.
Thu, Sep 11, 2014 9:36 AM
Russelln
Send a private message to Russelln
After reading all the threads from TIREDDOZER, I'm 99% sure this is my Brother. That being the case the Real Serial # of this D8 is 2U12593
Cat 12 Grader 8T6375
Cat D8 2U12593
Thu, Sep 11, 2014 10:15 AM
Reply to Russelln:
Hi OM,
S/No 2U 21,513 and up is correct as per the article. Yes, right at the end of production and Service Magazine, June 30 1953, announces that oil clutches are fitted standard from S/No 2U 21,513 and up.
Thu, Sep 11, 2014 10:59 AM
Reply to edb:
Hi OM,
Hi edb,
It's that 199335 s/n that I was questioning, not your service bulletin article.
Thu, Sep 11, 2014 12:26 PM
Hi edb,
OK penny drops--did not initially pick up that you were referring to someone else's post 😊
Thu, Sep 11, 2014 1:05 PM
TIREDDOZER
Reply to edb:
Yes I got the ser# wrong. I went off a used service manual with somebody else's #.
Thu, Sep 25, 2014 1:21 AM
