d8 2u dry steering clutches
Showing 1 to 6 of 6 results
boots
Send a private message to boots
in long term storage and inside a dry barn should I tie the steering clutch levers back on above tractor ? thanks boots will check back tomorrow morning boots
Tue, Nov 8, 2016 4:53 AM
In older Military weapons, long term storage of magazines with ammunition in them tended to make the spring take a set in the compressed position, hence not feeding well.
Consequently we were taught to not store magazines loaded for long periods.
Hence by tying the levers back, you may weaken the springs by storing it long term?????
What is long term anyways???
I would say take the drain plugs out if it is dry clutches to drain any condensation out, then drill 1/4" holes in the plugs and screw them back in.
This may totally be wrong information as I have not had to deal with steering clutch issues on a D8. (My Disclaimer)
Tue, Nov 8, 2016 8:36 AM
catsilver
Reply to drujinin:
You will have a job to successfully tie them back any way since they have a hydraulic booster, Dry store and lift the brake adjuster covers for ventilation.
Tue, Nov 8, 2016 2:45 PM
Thank you received: 64
Reply to catsilver:
You could always put some silica gel packets in the chambers and close them up. Dehydrate the packets periodically
Tue, Nov 8, 2016 7:37 PM
boots
Reply to catsilver:
believe I like this idea the best thanks all
Tue, Nov 8, 2016 8:10 PM
Thank you received: 52
Reply to boots:
D8-2U's do not have hydraulic steering clutch booster.
Wed, Nov 9, 2016 1:27 AM
Thank you received: 113
Hi, Boots.
If you are worried about the plates sticking together in the long-term storage, I would suggest taking the adjustment covers of the back end and bolting some brass or stainless insect screen over the openings to keep 'visitors' out. (Put the covers somewhere safe AND write yourself a note about where you put them. LOL.)
You could also remove the drain plugs in the bottom, drill them with around a 1/4" hole and put a slightly smaller split pin in the hole. When you do start it up working it again, the movement of the split pins in the holes will help to keep them open and effective as drain holes.
Wed, Nov 9, 2016 2:47 AM
