D8 1H runs again!
D8 1H runs again!
Showing 1 to 10 of 21 results
BrianCamling
Send a private message to BrianCamling
I got my magneto installed and timed, turned on the fuel to the carb, hit the starter and the pony took right off. So I engaged the pinion, ran the main for a couple minutes to warm things up, threw the compression lever to run and it started puffing smoke, shuddered pretty good and then all of a sudden the main engine took off!  I cut the gas to the pony and had to remember how to engage the clutch on the main to get it to move. But it went forward and backwards and the blade lifted and lowered just fine. I could only run it for a couple minutes because the fan belt broke and I didnt want to take any chances after so long since it ran last. But I am beyond excited to have the old girl running again. If I ever figure out how to post a video I will add it to the post. Thanks everyone for all of the advice over the last few weeks as I have tried to get it to run again. I have a lot of stuff to do yet but this was the biggest hurdle.
Mon, Nov 7, 2022 8:15 AM
BrianCamling
FYI I Have an MP4 file but no idea what to convert it to for a video to add here.If anyone has instructions I would appreciate it. I looked at the pinned article on adding photos but that didnt appear to be the same thing.
Mon, Nov 7, 2022 8:26 AM
Thank you received: 55
Reply to BrianCamling:
you can share it via the public folder in g drive or onedrive. all you need to do is post a link to that folder. this can also be a way to share large numbers of photos too.
Mon, Nov 7, 2022 1:50 PM
rustrunner
Send a private message to rustrunner
Reply to trainzkid88:
congrats. - ain't no better sound than an old D8
I
Mon, Nov 7, 2022 11:19 PM
BrianCamling
This might work. here is a link to my video
https://www.youtube.com/watch?v=AmAfdR_xwdE
Tue, Nov 8, 2022 4:03 AM
Thank you received: 140
Hi, BrianCamling.
Good stuff - thanks for posting.
Please correct if I'm wrong but it appears that somebody has 'transplanted' a late 2U/13A hard nose onto that tractor.
Tue, Nov 8, 2022 6:55 AM
8C 361
Thank you received: 12
Hi, BrianCamling.
[quote="Deas Plant. post=242228 userid=933"]Hi, BrianCamling.
My '39  1H  has the same setup. It has "DOB 1947" marked on the blade with welding bead.  Much better setup than that headache rack.
 [/quote]
Tue, Nov 8, 2022 11:20 PM
BrianCamling
Reply to 8C 361:
 [/quote]
So is the welded date something the plant would have done? I was wondering how to figure out the date for the blade and nose. I can look on mine this weekend and see if it has that
Tue, Nov 8, 2022 11:40 PM
8C 361
[quote=" post=242252 userid=3631"]So is the welded date something the plant would have done? I was wondering how to figure out the date for the blade and nose. I can look on mine this weekend and see if it has that
I assume the date was put on by the shop that did the modification. I have often  wondered what the history of my D8 brfore the blade was put on, farm Cat?[/quote]
Wed, Nov 9, 2022 12:25 AM
Hi, Brian Camling.
There MAY(??????) be a serial # on the blade but I doubt there will be any indication on the hard nose. The style of hard nose that you have on your 1H first came out on the 2U series from about 1950, about the same time that they changed the transmission from the old 'slide-bar' style to the '5-speed-with-forward-n-reverse' 2-lever arrangement.
The earlier 2Us had the radiator standing alone with braces up from the main frame to support it, allsame the 8R and 1H series. Then, partway through the 2U series, I think around 1947-48, they went to triangular side plates for the braces before they introduced the hard nose in around 1950.
Wed, Nov 9, 2022 12:28 AM
rustrunner
Hi, Brian Camling.
A lot of these old units are Johnny Cash tractors - 37, 38, 39, 40 , , , , , 49, 50 Caterpillar
Wed, Nov 9, 2022 12:40 AM
