D8 14A Strong vibration during attempt to start
Showing 1 to 10 of 10 results
4x6zh itzik
Send a private message to 4x6zh itzik
The pony engine works normally
First gear / or second gear mesh without any problem
Locking the clutch ....!
As soon as the clutch lever moves, everything starts to shake and the clutch is released.
Attempt to hold the clutch handle by force start the big engine.
I replaced the pony engine to another one .That did not solve the problem. everything shakes
I checked the gear on the flywheel and did not seem any harm.
What to do ?
Iitzk
When you say you replaced with another engine was the replacement a complete assembly, including transmission and pinion or just the engine itself?
Tue, Jul 31, 2018 3:11 AM
Thank you received: 77
Check the bearings in the pinion. Sounds like once you engage it, the vibration starts. Have you tried push-starting the tractor to eliminate the main engine as a source of the vibration?
Tue, Jul 31, 2018 3:23 AM
old-iron-habit
I think he is describing the pinion kicking out and shaking through the engage handle when he tries to hold it engaged. Sounds like a pinion problem, maybe a broke latch or even perhaps a broken shaft grinding? Is a video with sound possible to post?
Tue, Jul 31, 2018 5:46 AM
4x6zh itzik
Reply to old-iron-habit:
1. The engine is replacement a complete assembly, including transmission and pinion
The used part was unloaded from another tractor
2 . yes we push-starting the tractor to eliminate the main engine as a source of the vibration
Engine works without vibrations .
3. In the next attempt I will make a video.
4. The pinion kicking out and shaking through the engage handle ( Yes that is the situation )
5. This is an old video
https://www.youtube.com/watch?v=x8nWwwQX7pU&t=352s
First start about two years ago
You can see how the handle shakes.
At the 5th minute of the video
In general, the tractor is in very poor condition.
Itzik
Reply to 4x6zh itzik:
Itzik
Ya the pinion keeps disengaging and by trying to hold it in is tearing the crap out of the ring gear and pinion teeth!
Tue, Jul 31, 2018 9:25 AM
Kind of unusual to have two complete ponies act the same but it does sound like a pinion latching problem. There are two versions of latch mechanism, one version has twin dog latches and the other a centrifugal plunger release. The twin dog version is adjustable by changing the tension on the horizontal spring. The plunger type by adjusting the spring tension on the centrifugal plunger. If either the dogs or plunger is worn out adjustment isn't going to fix anything.
Tue, Jul 31, 2018 9:38 AM
4x6zh itzik
Ok
* Apparently there is no luck with this tractor
* Two motors have the same problem
* There will be no choice
* I'm going to open up the engine and look some surprises .....
* The problem will be to get the parts
Itzik
gemdozer
Thank you received: 25
Ok
Itzik
I have all poney parts if can help
Tue, Jul 31, 2018 6:21 PM
4x6zh itzik
Reply to gemdozer:
We'll open the clutch house
We'd love to be in touch
It will take a few weeks ....
If you have a choice I'd put the effort into the unit that has the centrifugal plunger release mechanism.
Tue, Jul 31, 2018 11:07 PM
