D8 14a steering clutch ajustment
razz
Send a private message to razz
Can somebody give me the specs to adjust the steering clutch on a wet deck D814a 8430. As in how many turns off of tight. Thank you Razz.
Tue, Mar 1, 2011 5:50 AM
Procedure is to back off the clutch yoke adjusting rods (counterclockwise) then tighten until all the clearance is removed between the yoke and adjusting rod nut. Then back off 2-1/2 turns for clearance. Should feel a click when turning the adjusting rod each 1/6th of a turn.
Tue, Mar 1, 2011 7:20 AM
