D8 14a finals
D8 14a finals
Showing 1 to 10 of 30 results
Pioneernorth
Send a private message to Pioneernorth
Good day everyone. I'm getting myself psyched up to rebuild my 14a. I have had this dozer for some time and just haven't got around to it. The final drive on one side has totally ate itself up. I have another partial (lower) half of another machine with excellent undercarriage. I am planning on switching the complete final drive from one to the other. My plan is to remove the final drive from the dead axle as one complete unit, thus not removing the sprocket from the hub. By pulling the outer bearing and housing after removing the dead axle nut I'm thinking I should be able to lift the whole thing complete with sprocket, housing and bull gear. This would save me lots of grief and $$ as I don't have the puller to break it all apart. Any thoughts if I am thinking right? Thanks. Pioneer.
Tue, Mar 29, 2016 5:50 AM
Oil Slick
Yes I believe you can unbolt the ham cases and everything will come off with it after the bearing holder is free. We pulled the bearing holder by pulling on the sprocket. I was surprised it worked too. The sprocket is not free after this, there is still the big nut holding it on behind the bearing.
[attachment=34603]image.jpg[/attachment]
[attachment=34604]image.jpg[/attachment]
[attachment=34605]image.jpg[/attachment]
The question is why are the gears chewed up? We just rebuilt a 14a with chewed up bull gears too.
[attachment=34606]image.jpg[/attachment]
We found both dead axles were slightly bent causing miss alignment between the pinion and bull gear. If you put a fresh bull gear on you might chew it up too. If you decide to swap out pinion gears you have to pull the steering clutches. A puller is required to pull the pinion flange off the pinion while in the transmission case. We could not get the pinion and flange to come out together on a wet deck 14a.
This is the simple tool we made to check the dead axle for straightness. It has a matching centered lip to fit the bearing race. We could rotate the blue piece and watch the all tread move away from the dead axle.
[attachment=34602]image.jpg[/attachment]
If your in this deep fix it right and be done with it!
Tue, Mar 29, 2016 11:06 AM
7upuller
Reply to Oil Slick:
Hey Team,
I have learned the hard way... All these older cats need to have the Finals torqued once a year back to spec. I was told up to 14-a and older models. Smaller tractors too. The 14-a with the most power on basic final design, would fail if not torqued to spec. I was informed to tighten the sprocket nut to 1200ftlbs once a year. If it starts getting loose it will bend the dead axle, then put uneven wear on bull gear. The pinion rides uneven on the bull gear putting strain on only a portion of the tooth rather than meshing the full tooth. The gears start to fail and chip off. That metal fragments then destroy the whole final and bearings.
All smaller cats need finals tightened too. I measured the front width (gauge) of tracks and compared the rear measurement. It was running an inch or more wider up front. I moved the tractor to a different spot and measured again. Almost 2" toe'd out. Started to ask questions. A seasoned mechanic instructed me to get right to the point and drain the oil from finals and see if any metal was present. Wow, lots of metal right side. So, I'm learning. Please all of you learn at my expense. Tighten your finals.
Glen[attachment=34607]image.jpg[/attachment][attachment=34608]image.jpg[/attachment]
Tue, Mar 29, 2016 7:16 PM
janmeermans
Reply to 7upuller:
Hey Team,
All,
Back in 1970, the contractor I was working for had one of his 14as in the shop and was into the right finals. The pinion gear was really torn up but I don't remember seeing much damage to the bull gear. I have no idea if he tightened his finals on a regular basis. If the Cat books said to do it, he probably did. I also don't remember how much other work they did before it went back together.
I am wondering it the pinion goes first before the bull gear? I also do not remember what they thought was the reason for the failure. If they blamed me, one of the operators, I never knew about it.
JanM
Tue, Mar 29, 2016 8:37 PM
7upuller
Reply to janmeermans:
All,
JanM
Hey Jan,
That Employer and I conferred. Yep... Hahaha, why is it on your mind... Did you do it???
The way I see it, the design of the finals handled the strain along the D8 line from the early 8's up through the 2u's. When the 13-a came around and then the 14-a's, the horse power on torque started showing signs of failures on the finals. They changed design after the 14-a.
So, I guess after Cat realized Jan was tearing up Cats, they had to step it up a notch or two... Hahahaha
Tue, Mar 29, 2016 8:54 PM
7upuller
Reply to 7upuller:
Hey Jan,
Hey Team,
Come to think of it, Jan did run my 14-a... And shortly after that... Rebuild time on the Finals... Something's never change... :doh:
Tue, Mar 29, 2016 8:58 PM
Pioneernorth
Reply to 7upuller:
Hey Team,
Thanks for the prompt and in depth responses! Now I have no excuse to get at it. Other than the snow thats still in the yard and the mud. Cheers.
Tue, Mar 29, 2016 9:25 PM
Thank you received: 7
Reply to Pioneernorth:
Glen/Mike, does the 14A have a single dead axle that goes from side to side, or one each side? What was the design change that Cat made with the 36A?
Wed, Mar 30, 2016 2:42 AM
Wombat
Donor
The 'H's had double reduction final drive, ie intermediate gear. Individual dead axles in all 8's
Wed, Mar 30, 2016 4:50 AM
catsilver
Reply to Wombat:
The dead axles on the D8H are much thicker than the 14A with a flange to bolt them tot he back end case inside the final drive, making the whole assembly stiffer, the outer track frame support bearing is a shim adjusted double taper roller, pressure fed with oil rather than the single bronze bush with 'sometimes' type greasing by the operator on the 14A.
Wed, Mar 30, 2016 5:41 AM
Reply to catsilver:
Cat gears are Crown Shaved to maximise longevity and allow for flexing of housings, axles etc. Without this feature "Will Fit" gears that are straight cut will break teeth off at one end if any misalignment is present.
In a real word of heavily loaded components it is almost not possible to stop flexing.
Have tested for Cat gears in final drives, etc. by using a 6" rule laid along the tooth face--if the rule rocks the gear is genuine--if it sits flat and does not rock it is aftermarket--many unhappy clients when shown this.
As a rule dozer machines bend the dead axles back--we swapped them side to side if still within specs. when doing both sides FD's.
Logging machines generally bend them forwards due to snagging a track on a stump or tree as an anchor to aid in winching.
Wed, Mar 30, 2016 6:01 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
