D7e48a
Showing 1 to 6 of 6 results
d7efarmer
Send a private message to d7efarmer
Put on new turbo, engine will not rev properly. Blowing blue smoke out of breather. Engine has no power. Lost some oil pressure. Was running good, engine is not missing. Old Magnet solved last problem. What do you think this problem is? Please Help! Thanks
Sat, Nov 26, 2016 2:38 AM
Thank you received: 23
Is the turbo the only thing that was changed?
Sat, Nov 26, 2016 4:45 AM
catsilver
Pull the oil filter and check what you find in it, I suspect a damaged piston, partially seized. has run a big end, dropped oil pressure and damaged the turbo.
Sat, Nov 26, 2016 5:38 AM
d7efarmer
yes only changed the turbo I suspect maybe a cracked piston but have not checked any thing yet used old machine about 200 hours with no problems but a lot of blue smoke coming out of breather like compression is bleeding back
Sat, Nov 26, 2016 7:50 AM
Ours had a lot of puffing blow by. Take off the oil fill cap and see if it puffs. Had a piston that was eaten up by combustion gases leaking by broken rings. When we tore it down you could still see the mark in the cylinders where the rings had been stuck over 100 hours run time previous.
Sat, Nov 26, 2016 11:59 AM
d7efarmer
tore into engine today spun rod bearing on the crank where is good place to buy complete reman engine
Wed, Nov 30, 2016 4:46 AM
d7efarmer
Reply to d7efarmer:
catsilver you were right about piston
Wed, Nov 30, 2016 4:49 AM
