D7E wiring
D7E wiring
Showing 1 to 10 of 23 results
cab
Send a private message to cab
Am getting closer to having my 47A ready to start. Need some instructions on wiring all the circuits.
Details:
12V 42MT starter
OEM delco remy 12V generator and voltage regulator
Glow plugs with correct cat wiring harness
Later Heat/Off/Start switch
1 - 8D battery
Ammeter
Working compression release fyi!
Need help on how the ammeter is wired in.
Need help on gen/voltage regulator wiring.
Need help on starter posts, which is which.
Thanks all! I did search first...
Tue, Nov 19, 2013 11:37 PM
DPete
Hmmm, will the glow plugs do their thing on 12V?
1962 D4C
Wed, Nov 20, 2013 12:35 AM
Thank you received: 43
Reply to DPete:
Normally wired 24v.
Here is a wiring diagram that should help.
Not aware of any 12v glow plugs for this application.
Wed, Nov 20, 2013 12:53 AM
cab
Normally wired 24v.
Perfect diagram. I can go off of that, thanks!
Don't know on glow plugs, maybe 12V gets them half as hot? Wonder if letting them heat a little longer would help.
On a separate note I remember someone touting an aftermarket source for first rate replacement seats. Can someone help me with that? Mine is completely shot.
Wed, Nov 20, 2013 12:47 PM
old-iron-habit
Reply to cab:
There is an ad in your magazine for the reproduction seats.
Wed, Nov 20, 2013 6:36 PM
rjh-md
Reply to old-iron-habit:
To start ,your going to need 2-8D batteries ,hooked up in series to produce 24 volts from 2- 12 volt 8D batteries,that is positive to stasrterfrist battery,negative,frist battery to positive of 2nd battery ,and negative of 2nd battery to a disconnect switch usually installed under the seat to a ground ,you need a battery box to install the 2-8D batteries side by side .Check to see if you have a 24 volt altnator
Wed, Nov 20, 2013 8:10 PM
If I remember correctly, glow plugs running on half normal voltage will put out about 1/4 of the heat they should. So, it will take LONG preheat times, but the amperage will be low enough that the battery will deliver the current for that length of time. Problem may be that the loss into the surrounding water jacket etc may outstrip the heat production.
Wed, Nov 20, 2013 9:07 PM
cab
Thanks. I found the seat guy, Hahn.
Will wait and see how glow plugs do on 12V in a warm climate.
Thu, Nov 21, 2013 9:26 AM
d9gdon
Reply to cab:
I got to thinking about this as it isn't the first time it's came up.
It might be worth making a junction somewhere so you can access your existing 12V glow plug lead and connect to another battery to make the 24V to your glow plugs only when you absolutely had to have it, like when it got really cold.
Fri, Nov 22, 2013 3:13 AM
cab
Reply to d9gdon:
I may see how it starts this winter and come back for help if it is lacking.
40 is cold for us.
Fri, Nov 22, 2013 5:40 AM
L364
Send a private message to L364
Reply to cab:
40 is cold for us.
Hi
12 volt glow plugs were available in some of the truck engines 1673 / 1674 / 1693 which had series parrallel switches, i.e. 12 volts system
with 24 volt start.
Therefore I believe the 12 volt glow plugs part numbers were [B]1P7912 or 6N0981 but these number proberbly will supersed to later numbers.
These numbers are from 1693 65B serial number.
Checked the 24V number between D343 and D342 and were same therefore believe the 12volts plugs should suit.
You should check with your local CAT dealer.
Best regards
Sat, Nov 23, 2013 1:22 PM
