D7E. Ways to drain coolant?
bobby1
Send a private message to bobby1
Bought another D7E 75E and does not appear there is much coolant in it. I want to know what is in it but cannot find an easy bolt or drain port. I was working on the 4 bolts on a plate under the radiator but they are REALLY on there and I am not even sure if it is worth the fight with them yet. Is there something easier to access? Can I get the engine drained?
Tue, Oct 29, 2019 4:56 AM
Paso Bob
There should be a hole in the left side of the hardnose to put a socket on long extension through and get on the drain valve.
Tue, Oct 29, 2019 12:40 PM
bobby1
Reply to Paso Bob:
Thanks. I was looking in that area for 20min just going off instinct. I do have a PDF manual but the explanation is vague and picture is not good. There is an arrow basically pointing at the water pump and says "open drain valve"...... I guess it was not obvious to me where it was. I did pull a plug that looked promising but had engine oil in it. I think the head of the trans cooler but appears engine oil runs in there as well.
Tue, Oct 29, 2019 2:21 PM
seiscat
Reply to bobby1:
Hello fastline, the best manuals are the originals that are often found on eBay. You will need the D7E 48A books - D7E 75E1 - 500 equals D7E 48A6393 - 6882.
D7E 75E501 - up equals 48A6883 - up (high hp). There's also a lot of good info in the Operation and Maintenance Instruction book.
These are the manuals I found on eBay for my D7E 47A (direct drive). It took a while but I was able to find manuals in great condition for way less than repop books.
Craig
[attachment=55824]2018-08-08 11.38.33.jpg[/attachment]
Wed, Oct 30, 2019 7:46 PM
bobby1
Reply to seiscat:
Craig
You know, that seems a bit controversial on the 75Es. The one in question is a 75E7xx, but the books I have direct from the military spec it at 165hp??
I seem to recall as you could determine the high/low HP models by the air cleaner type. Vertical style is low hp, and horizontal is high hp. This one has a vertical style.
Is there another way to verify the power output? I seem to remember the entire intake side was different, complete with different turbo?
Thu, Oct 31, 2019 1:47 AM
