D7E turbo question
D7E turbo question
cab
Send a private message to cab
I recently acquired D7 47A1554. Engine is apart but missing turbo. Am trying to source a turbo that would work. Is there any reason why the 4S9706 used on the later D7E wouldn't work?
My serial number calls for an 8M2679, which are pretty hard to come by. As long as the oil supply, return, and flange are the same, I believe it might be ok to use the later turbo, pn 4S9706.
Any thoughts?
Thanks a bunch.
Charles
Sat, May 25, 2013 7:50 AM
I think the later "high horsepower" engine's turbocharger will push more air than the older one. I have been told that unless you add/recalibrate fuel rate, more air means it burns cooler. Diesels usually operate with "excess" air anyway. More air doesn't change much except for the EGT. Add more fuel to the additonal air and you get more power and heat that must be rejected into the coolant and subsequently air.
Sat, May 25, 2013 8:43 AM
I have heard this is the place to find a turbocharger for most anything. MJM in Tuscaloosa, Alabama (800) 331-0616 | (205) 339-0616
Would be worth a call.
Sat, May 25, 2013 8:53 AM
cab
I agree with you if the turbo is strictly for the high horse, but I seem to remember that this turbo change occurred several hundred units before the hp change occurred, which would indicate that the rack change and governor changes were responsible for the increase.
This also begs the question, can I make this a high horse D7E by having the IP rack and shims recalibrated, with no ill effects? I do know for sure that the rod bearings on my crank are 2.5" in length and the high horse crank takes a 2" rod bearing. My first impression is that a 20 hp increase is so trivial that the prior crank/bearing setup would still hold up, but that is just a guess. Also there was a change in the air filter I believe.
Thanks for the tip on the turbo shop. More comments and thoughts would sure be welcome as I have some choices to make on the rebuild.
Charles
Sat, May 25, 2013 9:51 AM
gemdozer
Reply to cab:
Charles
I dismantled a d7-47a machine and am still have the turbo if I can help
Sat, May 25, 2013 4:55 PM
cab
Reply to gemdozer:
Yes i may well be interested. Please, if you can, give me serial number of dismantled 47a and part number of turbo. Also condition and price if you please.
Thank you sir.
Charles
Sat, May 25, 2013 9:20 PM
Thank you received: 39
Reply to cab:
Thank you sir.
Charles
The 8M2679 turbo produces 32 +/-3 in. Hg boost @ full load and speed.
The early 4S9706 turbo (160 hp) produces 25 +/- 3 in. Hg.
The same 4S9706 is used for the 180 hp at both 30 +/- 3 in. Hg. and 32 +/- 3 in.Hg.
Full load 1200 rpm stays the same with some variation in high idle speed.
Static rack settings and torque spring and spacers need to match the application.
The high hp versions run a 100 rpm higher low idle speed.
Sat, May 25, 2013 11:09 PM
cab
So if they are the same how does one deliver more air? This post stumped me old magnet!
Does the increased fuel delivery spin it up faster or??
For that matter from your figures it appears the older 8m2679 delivered comparable airflow to the high horse turbo. Thanks a lot for your wisdom and help, all of you.
Charles
Sun, May 26, 2013 3:51 AM
Reply to cab:
Charles
Yup, you got it, more fuel burning takes more air and increases the exhaust flow.
Sun, May 26, 2013 7:06 AM
