D7e Part Numbers Please
TGillotti
Send a private message to TGillotti
I am in need of some current good part numbers or sources for injector nozzles and a transmission cooler for a D7E 48A-6883-on up. Local dealer has them available, but pricey.  Hoping to find something good quality but a little cheaper. My pocketbook isn't very big, but she won't work without them.  Thanks for all the knowledge on here.   TG
Wed, Feb 5, 2025 5:57 PM
Thank you received: 11
Hi, TGillotti.
Giving your location would help others make some suggestions regarding sources. It mightn't be much help if you are in South Africa and someone tells you of a source in Japan.
Wed, Feb 5, 2025 7:07 PM
TGillotti
Hi, TGillotti.
Hi DP, I'm sorry. I should have remembered that this club is worldwide. I am located in northern Maine, USA. I did locate a cooler coming from Florida via a NY state company, but they can't come up with anything for injector nozzles. I also had a post on a different topic about the winch brake band. I did figure out that the band type is suppose to be dry and the disc type are wet. I have a seal leaking which is why my band was wet. Removed the winch (it had been run with little oil and much water and cooked the clutches) to take drag off off the engine, It doesn't seem to run much better. Before I bought it my CAT caught 3 mice in the air intake, and I found the turbo stuck. Got that freed up but bearings bad and slinging oil into the intake. Have one on the way also. I hope I'm getting it all narrowed down. Doesn't seem to be a high hour machine. Looks like mostly lack of maintenance and neglect. I got my fingers crossed. Thanks for setting me a little straighter. Take care............TG
Thu, Feb 6, 2025 8:55 PM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
