D7E Clutch Brake Replacement Question
Magneto
Send a private message to Magneto
The adjustment on the clutch brake on my D7E 47A is all used up and I assume that the brake band needs to be replaced.  The transmission grinds about half the time when shifting. The forward reverse lever also keeps getting loose on the shaft which doesn't help any. I have the service manual for this tractor however it is unclear to me as to whether the universal joint assembly needs to come out for this. Can the band be slipped over the joint? Any idea on parts availability?
Tue, Aug 20, 2024 7:38 AM
gemdozer
Thank you received: 25
NO You have to removed the bracket 9f7108 and removed the rod 6b4285 and you can removed the brake band 9f8979 and change the facing
Tue, Aug 20, 2024 6:44 PM
seiscat
Parts are still available.
Shoe assembly: 9F8992 about $69
---or the separate parts---
9F8976 facing  1
6B4284 rivet  4
9F8979 band 1
Craig
Tue, Aug 20, 2024 8:11 PM
Magneto
Reply to seiscat:
9F8976 facing  1
6B4284 rivet  4
9F8979 band 1
Craig
Thanks guys, you saved me a lot of unnecessary work. I have the parts on order from the local cat dealer.
Tue, Aug 20, 2024 9:22 PM
DManring
Send a private message to DManring
Reply to Magneto:
Hey, yeah I thought I’d add in. I’m working on a 73T the shoe holes or walled out pin that a pivots on walled out so I ordered them from the local cat dealer to be here Friday.
Wed, Aug 28, 2024 4:06 AM
