D7E 48A550 339 engine -head torque specs
716thMP
Send a private message to 716thMP
I have my heads back and ready to install them. Would like the torque sequence and the torque for my engine.
I have my head gaskets.
But I need part number for the small head gasket that would be the one for left side of the block,. Thank you John
Thu, Sep 15, 2022 9:16 PM
Gasket (2-req'd) part # 9M7302
Have you checked proper liner protrusion?
Head torque....
 [attachment=68933]D339 Head Torque.jpg[/attachment]
Fri, Sep 16, 2022 11:34 AM
716thMP
Thank you Old Magnet. I had Caterpillar mobil tech check projections. The worse .003-.005 on all cylinders. .003 was one #2 cylinder. The #2 was where the head was cracked from valve all the way to injector port and up into the block causing the block to be unrepairable.
It all started with combustion leak into radiator. I was hoping for a bad injection sleeve; but it was a lot more. The radiator was the wrong one for that Cat and the core was unrepairable requiring $5000 for a new core. Then a cracked head that was junk requiring a new one. And the head for #3 and #4 cylinder that looked alright; I sent in to machine shop And it was a good thing that I did. The exhaust valves were cracked through the valve and valve springs needed replaced. And the head needed to be resurfaced.
I suppose I will receive a lot of criticism for pouring so much money in the old girl. But I could not see junking it. So I appreciate all the assistance I receive.
Sat, Sep 17, 2022 6:03 AM
seiscat
Reply to 716thMP:
Hi 716thMP, Thank you for keeping 48A550 alive! I think you will find these manuals helpful and will save you time and money. The Parts Book is available in the library.
Take care to follow the instructions in the O.& M. I. especially about the final drive bearings, final drive parts are scarce!
Craig
Operation and Maintenance Instructions:
https://www.ebay.com/itm/374199398159
Service Manual:
https://www.ebay.com/itm/394221144054
Sat, Sep 17, 2022 8:16 AM
Thank you received: 32
Reply to seiscat:
Craig
Service Manual:
oh the fun of old gear. and buying second hand. its your money spend it how you wish
Sat, Sep 17, 2022 1:36 PM
