D7E 48A ser.2472 Cable/Tilt
Priceless
Send a private message to Priceless
Who or what company made the air cleaner for my 48a? I can't read clear but 3s5775 part number is a good guess. It is the one with the paper filter and mine is rusted a lot (its vertical), I believe a used one could be bought cheaper than POR15 this one. If you know what I am looking for would you have a parts number for it? Thanks, Lex
Mon, Jul 6, 2026 12:38 AM
gemdozer
Thank you received: 25
The 48a 2472 should have 5s4162 parts number aire cleaner
Mon, Jul 6, 2026 1:30 AM
Priceless
Thanks, I know I should get the right book but ........... I am thinking any used Cat cleaner will have the same rust problems but on a semi truck I haven't found them to take on water like these vertical cleaners on Cats. That is why I am looking to see if Donaldson or another manufacturer made these for Cat. and if so what would there numbers be. Actually I only need the two sections below the paper filter, the top is ok going to the turbo.
Mon, Jul 6, 2026 2:01 AM
