D7e 48a 5960 reversible fan.
Dalton808
Send a private message to Dalton808
Thanks in advane for all the help and thanks for the super helpful anseers on my other questions.
We are on a job and we're having cooling issues. We have flushed the ssystem and radiator and have changed the fan belts and thermostats and cleaned the fins.
But she still gets hot after a while of running. We have a reversible fan. I have a manual but it doesn't show anything but the fixed fans. My question is is there just forward and reverse ? Or a nutrual or can you adjust pitch ? Our fan blades seem almost flat aND don't seem to move much air up at operating rpm.
Sat, Feb 18, 2017 8:23 AM
657cat
Send a private message to 657cat
It. Sounds like your fan blades are needing to be turned. They push in and turn, make sure they pop back out or you might have a wreck. The fan should blow out the front fairly hard at high idle. When you turn the blades there should be a noticeable pitch to the blades again.
Sat, Feb 18, 2017 9:10 AM
Thank you received: 35
Hi Dalton,
it is well known that the fan blade keepers in the hub at the base of each blade stem wear and so the blades flatten out as you have noted.
We saw this a lot on 769 dump trucks and anything else fitted with them after many hours of operating.
Overheating due to loss of cooling air flow thru the core is the end result.
Better to get a fixed blade fan as I do not think the reversible units are available new anymore--a used one is likely heading the same way.
As a temporary fix reverse the fan and continue operation.
I believe the intent of them was to reverse the fan to blow trash from the core or for easy reversal for winter summer operation etc.
If money was really tight you could likely dismantle the unit a weld up the worn components to re-use your existing unit.
Air flow figures are given in the scan below as well as the areas of the core the expected air flows are to be taken.
Areas of the core clogged with trash inhibiting air flow will be evident by low air flows--a worn lowered pitch adjustable fan will be down on flow in all areas.
To check externally for trash in fins look in from the front of the core and use a work light behind the core to check for trash in the fins--dull or no light evident in clogged areas.
Also is a chart for expected coolant temperatures at given locations in the cooling system for diagnosing an overheating cooling system.
In older systems the engine oil cooler tubes at the water inlet side from the water pump can clog with crud from a rusty or dirty cooling system.
Hope this helps,
Sat, Feb 18, 2017 9:11 AM
Dalton808
Reply to edb:
Hi Dalton,
Hope this helps,
Thanks for the info. I'll try to get those blades turned around. I'll post some pics of the blades when I get back to the machine.
Sat, Feb 18, 2017 12:39 PM
