D7E 47A Trans Weak
D7E 47A Trans Weak
DWC7
Send a private message to DWC7
I bought a D7E 47A back about 2-3 years ago. Just started using it in the last 6 months on the weekends hard. I have notice over the last few weekends the tranny has started to loose tourque. I set the clutch tension back about 6 months ago and oil is good and clean.
Where do i need to start looking. Wont pull much in 2nd gear. 1st will still push faily well but have noticed its not spinning the tracks at all and we have sand it should dig some. Is the clutch plates getting wore and weak? Can i possbily adjust the clutch engagment again and get along for a while? This is just a ranch dozer that we use to rake behind our D7G. So its not abused every day.
Sat, Nov 23, 2019 2:28 AM
bluox
If your tractor has a clutch it won't have a torque converter.
Adjust the clutch.
Bob
Sat, Nov 23, 2019 2:33 AM
DWC7
Reply to bluox:
Adjust the clutch.
Bob
[quote="bluox"]If your tractor has a clutch it won't have a torque converter.
Adjust the clutch.
Bob[/quote]
I know i edited it out. Our HD11 is direct drive with a torque converter. I had the 2 confused.
Sat, Nov 23, 2019 3:30 AM
seiscat
Reply to DWC7:
Adjust the clutch.
Bob[/quote]
Here's the specs for adjusting if you don't have them.
[attachment=56098]IMG.jpg[/attachment] [attachment=56099]IMG_0001.jpg[/attachment] [attachment=56100]IMG_0002.jpg[/attachment]
Craig
Sat, Nov 23, 2019 3:47 AM
