D7E 47A Blade Working Now - Hooray!
farmerfred
Send a private message to farmerfred
We took the entire cover off, blew out all the debris from around the brake band, which was full and
made sure all the joints were free and working, and then adjusted the brake with the cover off.
I could get the brake to release with the handle, then put the cover back on, set the clutch, which is really
touchy, and it works fine in the yard, but I haven't taken it out and run it up against anything yet.
After I took that cover off, I could see how the linkage works so the adjustments all made sense.
Thanks for all the input and advice.
Mon, May 21, 2018 9:16 AM
Glad to hear! nothing works better than a clean well oiled machine. lol
Mon, May 21, 2018 9:23 AM
Thank you received: 98
Hi, farmerfred.
Good Stuff. I apparently posted my reply to your previous thread while you were posting this thread as this did not show when I first saw your earlier thread.
Now go out and enjoy it.
Mon, May 21, 2018 9:32 AM
DPete
Hi, farmerfred.
Yay, now as the brake wears the roller will move so you put it back in time when it does, it will probably stay a long time depending on how much use it gets. About the pressure plate adjustment, as Deas said leave free play or it will get hot and cook grease out of the seals and into the clutch discs, then you have a mess. Doze on
1962 D4C
Tue, May 22, 2018 5:17 AM
