D7C brake sticking
D7C brake sticking
rustyfender
Send a private message to rustyfender
My D7 s/n 17A 5563, brake has been sticking for a year or so, works fine, just have to push pedal hard and pull it back by hand, seems worse after machine is up to operating temperature. I have looked inside brake compartment, sprayed all pivot points , seemed to look normal. This is on the right side sitting on the seat.
Sun, May 21, 2023 3:01 AM
seiscat
Probably worn shaft/bushing of the brake pedal. This allows dirt/rust to build up and cause the sticking. Take the pedal off and just clean it up for a temporary fix.
Craig
Sun, May 21, 2023 8:41 PM
rustyfender
Reply to seiscat:
Craig
I have unhooked the pedal mechanism and lubed it and it moves free, problem must be inside the housing so where.
Sun, May 21, 2023 8:54 PM
seiscat
Reply to rustyfender:
The parts book I have is for D7D 17A11,879 to 19,442 Sorry. Maybe Old Magnet or someone else on the forum will help.
Good luck,
Craig
Sun, May 21, 2023 11:32 PM
rustyfender
It seems to be stuck where the pedal rod goes through the steering clutch housing
Fri, May 26, 2023 5:56 AM
