D7C 17A oil leak.
D7C 17A oil leak.
Showing 1 to 10 of 12 results
KarlRobbers
Send a private message to KarlRobbers
I have a Cat D7C 17A series, with the big old slow revving 4 cylinder in it.
The beast has developed a leak from the head gasket area at the front of the motor, so I am guessing that this is a head off job. Thankfully there are two, two cylinder heads rather than one big one.
Firstly are there any tricks I should know about before I remove the head or put it back on?
Secondly, does anyone have the head bolt torque procedure, (steps, order and torque) and the valve adjustment procedure, (order, clearance, timing marks and clearances).
I may just try retorquing, (wishful thinking), as the machine doesn't blow bubbles out the radiator, the oil is not milky and it runs strongly.
Has anyone come across this before? What caused it?
If somebody had a manual, I would be interested even.
Thu, May 23, 2013 1:27 PM
The torque procedure depends on whether you have the thick hardened washers and hardened nuts.
with older style nuts and washers.............
first step 5/8 nuts starting with the center one in the middle of the head 60 foot pounds
then tighten the ones to the left and right of it
next move to one of the outer row of 5/8 nuts where two are side by side and tighten both of a pair
then the single nut on the opposite side of the same cylinder
then the single nut on the other cylinder
then the pair on the opposite side.
7/8 nuts first step 150
start with the first two in the middle of the head and then do the outer 4 in a criss - cross pattern
repeat 5/8 at 90
repeat 7/8 at 200
If hardened nuts
second time
5/8@120
7/8@300
I would certainly try a retorque before removing the head. I expect your leaks are around the pushrod/lifter openings or the port that brings pressurized oil through the deck into the head for the rocker arms.
I cannot tell you where to find the timing marks on the flywheel/clutch housing, but normally there is a small cover that you remove and you can see the pointer and flywheel. There will be 2 TDC marks, one with 1-4 and the other with 2-3 cylinder pairs. When each mark is lined up with the pointer, the valves on one of the cylinder pair will be closed and can be adjusted to 0.016" hot. So retorque the head when the engine is cold, replace the valve cover and run it up to operating temperature and then adjust all the valves.
firing order is 1-3-4-2, so adjust a set of valves, turn the engine 1/2 turn and adjust the next pair, turn 1/2 turn..................
If you have the head off, you can put the engine on TDC and make a mark on the front crankshaft pulley for TDC and use that to adjust the valves. Plenty accurate enough for that.
Remember, if you use the decompression to make the engine easier to turn by hand, flip it back to run before adjusting the valves each time!
Thu, May 23, 2013 7:38 PM
Thank you received: 19
repeat 5/8 at 90
repeat 7/8 at 200
If hardened nuts
second time
5/8@120
7/8@300
Timing pointer is under the small cover on the top of the flywheel housing.
Be shure to use a sealer when replacing the head/gasket.
I'd recommend the Permatex 300 version.
Thu, May 23, 2013 9:08 PM
KarlRobbers
Thanks for the replies so far!
Thu, May 23, 2013 9:48 PM
Reply to KarlRobbers:
From my files....
Thu, May 23, 2013 9:52 PM
bluox
From my files....
[ If you have a oil leak replace the rocker box gaskets. There are no oil passages in the head gasket.
Good luck
Bob
Fri, May 24, 2013 12:52 AM
Reply to bluox:
Good luck
Bob
There are two oil lines, one for each head, that pass through the block to the heads that use ferrules and seals at the head to block joint that could possibly leak.
Fri, May 24, 2013 3:02 AM
rjh-md
Reply to bluox:
Good luck
Bob
I would susject that after you get it back running ,bring the engine up to operating temperature at half to 3/4 high idle for 1/2 hour ,and retorque the heads . You will probably get a 1/3 to 1/2 turn on each nut
Also while torquing the heads cold ,go over the sequence of torque at least 3 times .Same hot .The down side is you will have to remove the rocker arm assembly to do this ,and readjust the valve clearance .
One other thing that may be worth checking is the crankcase breather to be sure its not clogged .Wash it out in parts wash ,and blow it out
Fri, May 24, 2013 3:20 AM
KarlRobbers
Reply to rjh-md:
I am certainly, I will try the blocked breather idea, (I think I will do cartwheels if that works!).
I also studied the parts book a little more and discovered that there are two head gaskets per head, it seems that one does the compression side of the deal and the other seals around the pushrod area. Also I "discovered the seals and ferrules that have been mentioned.
Although it probably doesn't seem it at this point, I am actually not too bad on a set of spanners, but most of my work has been on newer machinery and they do things somewhat different.
On the plus side, I have sourced a manual, out of France of all places, so that should be here in the next couple of weeks😊
I really hope I don't need to pull the heads, but I have a strange feeling I will be. My luck is never quite that good!
Once more, thanks to all who have replied thus far, I do appreciate it.
Fri, May 24, 2013 8:03 AM
Tim Matthews
Send a private message to Tim Matthews
How do you describe your leak ? running profusly or dust gathering black
Im just saying if shes not bleeding just give her a bath once in a while .
Fri, May 24, 2013 8:56 AM
zip
Send a private message to zip
Depends on how bad it is leaking! You mite open up a can of worms, sometimes better left alone!
Fri, May 24, 2013 8:58 AM
Earlcoate Charity Open Day
