D73T transmission / bevel gear lube
SpragueM
I need to drain the ice/water out of the transmission case. I see there is an additional drain for the bevel gear case. Are the two filled from the same fill tube? If not where is the fill location? And how much of what?
I guess I need the operators manual for this since the service manual gives no information.
Matt
Mon, Dec 27, 2010 4:55 AM
gemdozer
Thank you received: 25
Yes you refill to the same place and need 11 gal. 80/90 oil
Mon, Dec 27, 2010 5:14 AM
