d717a 15544
d717a 15544
Showing 1 to 9 of 9 results
clogs
Send a private message to clogs
part needed which is not available nom is4m9996 tube assem
if anybody can help please leave message on here
many thanks clogs
Sat, May 2, 2015 12:34 AM
clogs
thread not compleat should read part no 4m9996 tube assem if anybody can help
please leave massage on here
many thanks clogs
Sat, May 2, 2015 12:49 AM
mrsmackpaul
Reply to clogs:
many thanks clogs
gudday clogs any chance of picture of said part might make it easier for people to keep a look out for one for you
Paul
Sat, May 2, 2015 2:32 AM
tailseat15
Send a private message to tailseat15
Reply to mrsmackpaul:
Paul
I agree with ^ this part # is not listed in my Numerical Parts Index. In fact the highest alpha numeric listed is 2L6872.
O.P.- are you sure about the part number, or perhaps that is a later part number that crossed over? What part is it, or what group is it from?
Sat, May 2, 2015 7:54 AM
Thank you received: 30
Reply to tailseat15:
Says 4M9996 = Tube assy/turbo oil drain.
Sat, May 2, 2015 8:37 AM
tailseat15
Dangit beaten by Old Magnet again!!
Good job. My book is older than the turbo models.
Sat, May 2, 2015 9:36 AM
clogs
old magnat is right again if anyone finds one please let me know
thanks clogs
Sat, May 2, 2015 2:35 PM
gemdozer
Thank you received: 15
Reply to clogs:
thanks clogs
The tube 4m9996 is connect on side base on head under valve cover
Sat, May 2, 2015 5:31 PM
clogs
Reply to gemdozer:
if anyone knows where in u.s.a. there is one for sale please let me know
as I can then import said part
Sun, May 3, 2015 9:11 PM
Inter674
Reply to clogs:
Presumably like mine the turbo oil supply and return pipes are rusted out from repeated exposure to heat and moisture - rusted from the outside that is. They look pretty basiic so I wondered if you have thought about making them yourself or getting a small egineering shop or hydraulic repair shop to replicate them. My guess is that the Cat part might be available but it will be costly. Bendable pipe such as oil supply/hydraulic pipe is readily avaliable and you will probably be able to transfer the end fittings across or fit new ones.
Just a thought.
Mon, May 4, 2015 3:12 AM
