D7 Pony motor starter R&R
jonstark
Send a private message to jonstark
Can I remove only the motor from the starter assembly or must I remove the entire assembly to access the starter motor? I let the smoke out of the start switch yesterday and need to refill it.
thx,
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Mon, Jul 22, 2013 9:03 PM
dick
Send a private message to dick
You don't need to remove the bolted on housing, just loosen the jam nut and back out the setbolt which retains the starter. It should slip out unless rusted in place. If only the switch failed you can remove it without loosening the starter.
Mon, Jul 22, 2013 9:22 PM
Thank you received: 61
Reply to dick:
I have a D2 pony started that was rusted into the retaining ring, so I heated the ring up with the mapp gas, let it cool with some Kroil, and then (gently) pushed it out with the press. Not sure if you have the press option for yours?
Mon, Jul 22, 2013 9:45 PM
jonstark
Reply to dick:
It slipped right out as soon as I loosened the set screw. Whew!
jon
Tue, Jul 23, 2013 3:14 AM
