D7 Pony Engine chuffing out the crank start opening
Showing 1 to 10 of 21 results
TOP
Send a private message to TOP
Thank you received: 16
My pony engine chuffs fume out the crank opening even after I cleaned the breather very good. What is the fix and how hard is it to do and find parts?
Wed, Aug 14, 2024 8:45 AM
CrawlerAddict
Thank you received: 14
Sounds like blow-by around the piston rings. I have a pony on a D4 that'll shoot the dipstick out along with most of the oil if you run it with the filler cap on.
Best of luck,
CrawlerAddict
Wed, Aug 14, 2024 9:28 AM
TOP
Reply to CrawlerAddict:
Best of luck,
CrawlerAddict
That is correct but the blowby got better with a little use Also the breather was blocked originally due to lack of service. 30 minutes in the ultrasonic cleaner helped
Wed, Aug 14, 2024 9:59 AM
D8Dude
Thank you received: 28
Reply to TOP:
Do you mean it's fuming from the hand crank right angle drive?
Wed, Aug 14, 2024 12:18 PM
TOP
Reply to D8Dude:
[quote="D8Dude post=258651 userid=17573"]Do you mean it's fuming from the hand crank right angle drive?
 [/quote]
That's exactly what I mean.Seems like there should be seals to prevent that.
Wed, Aug 14, 2024 3:48 PM
D8Dude
Reply to TOP:
 [/quote]
There is a seal in there, it's fairly easy to replace, it was still available through Cat when I replaced mine a few years ago.
Wed, Aug 14, 2024 4:23 PM
TOP
Reply to D8Dude:
[quote="D8Dude post=258654 userid=17573"]There is a seal in there, it's fairly easy to replace, it was still available through Cat when I replaced mine a few years ago.
 [/quote]
Do I have to take the whole housing off the side of the engine or can it be replaced with the housing in place?
Wed, Aug 14, 2024 5:56 PM
gemdozer
Thank you received: 25
Reply to TOP:
 [/quote]
I am still have some 17a poney used parts
Wed, Aug 14, 2024 6:23 PM
D8Dude
Reply to gemdozer:
The housing needs to be removed from the engine. From memory, there's a plug in the bottom that you can take out to push the shaft out of the gear and the housing.
Wed, Aug 14, 2024 6:48 PM
Thank you received: 78
Reply to D8Dude:
Would it be possible to use the self-tapping screw trick to get the seal out or is it too tight in there?
Wed, Aug 14, 2024 7:04 PM
TOP
Reply to D8Dude:
[quote="D8Dude post=258658 userid=17573"]The housing needs to be removed from the engine. From memory, there's a plug in the bottom that you can take out to push the shaft out of the gear and the housing.o
 [/quote]
Yes, I suppose it makes sense. The seal would never pass over the two pins on the shaft in order to get it out the front.
Thu, Aug 15, 2024 3:56 AM
